Hey I was just wanting to find out some info/problems/advice or if any one has done or heard of turbo engine swaps for 1981-1985 HR/DR/MR30 Nissan skylines such as L28et, RB30det, RB20det, RB25det any others because I am curently thinking seirously about puting on into my HR30 4 door Non turbo because I have a bit of coin saved up. Also any photos of your modded R30s would be greatly apreiciated. THANKS.
I have an L28E in mine, was going to turbocharge it but a manifold was about $1500 minimum.
Then i thought of an RB25, but thats going to cost atleast $7K.
Since then its been crashed i am getting it fixed selling it and buying a S132 with RB25DET
theres a few r30s out there with some swaps
best is prolly http://nissanking.cjb.net
thats what i'll be doin to mine, just need to find the appropriate parts for my motor.
from what i've read for the r30
rb25 needs to have the sump modified
rb20 goes in with minimal mods to gearbox mounts
rb30 sits too high requiring either bonnet raised or sump cut n shut
all swaps are over about 6k cause u gotta change heaps of stuff like diff brakes zorst prolly cooler and so forth
thge rb20det is a direct replacement, talk to justeck and they will give you the information.
all they said to me is.
The mounts line up. you have to rewire the wring harnes for the Pas and Cas. use the Rb bell housing and you can use the l20et gearbox.
thats it simple :D stock wiring harnes, just swap and go :)
when i did the rb20 swap it was a little more difficult then that as we found the gear box didnt line up (bolts), replace the brake master cylinder for the r32 one, engine needs lifting and if you have a mate that is a auto sparkie it will say you a lot of cash, 1000 to re-wire to suit new system?
