Drove past it yesterday, heaps of space, an unused runway just sitting there, easy access off road, far away enough from houses.
Wouldnt it be great if someone converted it to a drag strip? Who works for the council and can put forward the recommendation?
https://www.sau.com.au/forums/topic/255097-old-airport-at-pelican-newcastle/
  • Replies 47
Bakes i drive past it all the time and think...wow nice 1/8th mile strip!
Guess what...it cannot be rezoned and houses built on it.
The residents would whinge but when they bought there it was a bloody airport!
It would make a great practice strip for use Newy's guys to check our short times, changes to our set-up and shake down passes after major work. I hate going all the way to Sydney to find out something is not right with the car.
Edited by DiRTgarage
would be awesome but you know what will happen, wasnt there someone trying to build a racing complex out the back end of the terrace but kept being knocked back by council because of noise polloution - theres no houses for around 3km by the way,
yes...it was the people who own this facility...
http://www.motorplex.com.au/
heck i would even put down a run for shits and giggles if there was one there.. i know that driving for 6 seconds (if its a 1/8 mile) in a straight line is boring but meh... its a cop free, tyre frying thrash.
Drag racing is as boring as bat shit...especially if your car is slow...but it would be fun to have a local strip where we could tear it up.
I dont know how long the actual strip is but id say its not 3/4 of a mile long which is needed for proper 1/4 mile action.
If you can run a 6 NZM.031 your doing very well.
Here is an old pic from when it was open a couple of years back. Now it just sits there abandoned.
There may be enough room to make the strip longer for 1/4 mile.
Does SAU want to buy it and convert it to a drag/race/drift track? :P
i measured it on google earth from that white line you can see, to the dashed line at the other end, i got just under 900 metres.
it's too short ?
i'm not sure what sort of stopping distance you will need, for me. about 10 metres lol.
So, at the end of the runway (not pictured), what is there?
Lake Macquaire one end, Pacific Hwy the other.
Google Maps
And FYI, it has only recently changed hands. And the right side boundary in that photo is approx 950m.
Edited by hydie
how much does he want for it??
Lol. More then you can afford pal, airstrip.
Lets just say a fair bit... and then some. The newest owner (company anyway) won't even consider selling it for a while anyway from what I have researched.
Edited by hydie
[...anyone have new owners details?
Yeah. Jeff McCloy owns it and he is having drama's with council over it, so you guys have no chance. And no-one could afford to buy it off him anyway.
We're not interested in buying it from him, just helping his cashflow out a bit :P
Do you have any contact details for him please? All I'll do is mention what we plan on doing and the sort of rent we'll pay for a facility for one day, if that works for him then great, if not its only a phone call lost
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
