you took my Sunday spot !! j/k
i think 16" suit 32 best but myself am using 17.. isnt 265 a bit too much?
ohh really?? lol i know his got another car to do sunday too... so blame them :P
will look awesome once the guards have been massaged :banana:
maybe lower it a tiny bit if possible.. stay away from bodykit i reckon
yeh once i get those gaurds out a bit ill maybe put her down only a lil bit... yeh i agree i dont like the body kits too much.
https://www.sau.com.au/forums/topic/255423-new-rims-19s/#findComment-4407923
it looks good, make sure to post some pics. im with you on the body kit, id only put a gtr kit on an r32 cause i dont think you can get any better looks than that on a 32.
haven't seen ya driving around lately. i keep seeing that horrible pink r34. anyway im sure ill run into you, and maybe stirlz as well, when his is running properly again.
https://www.sau.com.au/forums/topic/255423-new-rims-19s/#findComment-4408009
Nah havent even seen ur 34 on the road man!! ohh that 34 i see everywhere! he has distroyed the look of that car!!
Yeh was speaking to him the other week about his problems... cant seem to find it, was meant to help him diag his comp... is he a member here?
https://www.sau.com.au/forums/topic/255423-new-rims-19s/#findComment-4408141
yeah he posted his problem on hear a few weeks back i think his user is stirlz.
https://www.sau.com.au/forums/topic/255423-new-rims-19s/#findComment-4408529
looks the goods! How wider are they and offsets?
fronts are 8.5 (235) +18 offset
Rears are 9.5 (265's) +40 offset
that looks sweet mate! :happy:
are those the hiro rims? maybe lower the back a bit
Nah Axis, yeh once the gaurds are "massaged" ill lower it just a tad
https://www.sau.com.au/forums/topic/255423-new-rims-19s/#findComment-4410029
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
