well let me tell you im impressed lol i didnt think it would get so high on my street tune, pump gas and meth injection 30psi on with my gt35r for those who dont know my car its a stock cammed rb25 port n polished greddy intake q45 TB china header gt35r .82ar haltech e6x tomei rods cp pistons STOCK OIL PUMP(dont get a heart atack all you crank collar horror story nuts) chinese intercooler 850cc sard injectors rest is basically stock, i have a nitrous kit isntalled i was goin to put a 50 shot on it with my pump gas tune until i saw how much power i was making and decided to leave it at that lol i guess ill put a 100 shot and c16 for the track heres some vids on the last vid you can see on the screen the real time hp readings the torq was out of wack cause our ts-1 rpm meter was broken soo rpms were all over the place
  • Replies 136
congrats on the power run, that is very big power for your setup...
reason why others modify what you havent is for reliability..... ie oil pump...
eh ihave a nifty little device that when my oil preasure drops below 20 psi on wot it turns off the car its a nifty little idea i stole off 2rismo thnak you budy :) i am goin to go with a single stage external pump soon just need to fill up the pockets again
Nice power, but it'll be interesting to see how long it lasts until something goes pop.
until something goes pop? car has been runing for over a year and a half on those numbers just first time i had a dyno available, its my daily driver lol, explain your theory on why something would go pop(other then the oil pump which is taken care of) car has no knock afr's are perfect intake temps are perfect, im only at 7800 rpms, your comment is just funy....
Edited by ReganGTS25T
a knock sensor DUH!!!!!
rofl a knock sensor conected to a little box that has a head phone output to it and you can hear everything goin on in the engine its english made dont remember who makes it though
How many knock sensors are you using ? where are they mounted?
600 Peru power sounds impressive.. i wonder how many aussie kw's that is....
Heh, didn't see your post about your oil solution.
Peru power rocks my world. :)
lol 2ris .... rawr both you and antony got to beat my et :) good luck wonder if that rb30's bark is worse then its bite
11.1 @ 132 mph not bad for a dusty landing strip in the middle of the dessert eh
your MPH converts your Peru kw's into about 380 aussie kw's.
Still thats awesome results. Well Done.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
