Hey Guys
Just wondering what the going rate is these days to get a r33 gts-t engine built to handle 400rwkw, i want it to be a strong engine, not an engine i will just boost up for the 1/4 mile. As i am in melbourne which turbo mechanics would be best to go too?. I want to spend about $9,000 tops on the engine internals to achive 400rwkw, do you guys think this is posible on this budget?
What type of modifications can i aspect for $9,000?. The turbo is not included in the $9,000 as that will be purchased in the near future.
Cheers Guys for your help
Shaun
Let us know how far you get with $9k. I've learnt that yes you may spend 9k on the engine but your going to spend about the same or less on suspension, diff, computer and so on. I would get expert advise before i went ahead and built a 400rwkw bottom end. Pm Sydneykid as he knows alot about this sort of work.
Good luck
Harun
Hi Shaun, I really need to know a few things before I can comment;
What have you already done to the car?
What is your horsepower target?
What are you going to use the car for?
What work can you do yourself?
What is your budget?
Be realisitic in your answers and I will try and give you reasonable suggestions to suite.
Hey thanks guys for the replys,
Hi Sydneykid, ok so far i have a stock as a rock R33 Gts-t, things like exhaust sysytem are no dramas as my mate works at an exhaust shop. Horsepower target hopefully will be around 600Hp, (447rwkw i think). The Budget i intend to spen on "JUST" the engine alone is $8,000 - $9,000, i have a totally different budget for other engine parts. So The Engine has to be built to handle 600Hp for $9,000 is this possible?. The intend use for this car will be a bit of every thing 1/4 mile, daily driver and drift car:D. I will be able to do some things myself but other thAn that i can get it done threw my mates or if worst comes to worst, threw a turbo workshop. So Rember ($9,000) to Spend on engine internals, cams, rods, pistons ect ect all the stuff to make a stable and slightly worked rb25det engine.
Thanks for the help guys
Shaun
PS: I want to build me car around the JMS R33, but without stock internals:p. Turbo i will be using is a Garrett GT 3540.
Firstly you said bottom end, then referred to cams etc, so i take it you mean engine internals.
A budget of $9000 will probably get you the pistons, rods, cams, valvegear, but my concern would be that at those sorts of power figures, what is a realistic km expactancy for an engine with so much hp/Litre. 160kw/L at the wheels is a lot of power.
If driven as you would expect such an engine to be driven, is it reasonable to presume every 10,000-15,000kms that the engine should stripped and inspected... afterall it is a hell of a $$$$ investment.
YEah - I don't think you will get 447rwkw out of the Rb25 without doing somehting radical like stroking it and putting a huge turbo on...
But if you do - I wanna see that !
Good luck dude ! :(
Hi Shaun, we have a 3.1 litre engine on the engine stand, it has;
JE forged Pistons
Total Seal gapless rings
Carillo forged conrods
ARP rod bolts, head and main studs
Balanced and linished crank
9 to 1 compression ratio
O'ringed block
HKS exhaust manifold
Garrett GT3040
Clevite bearings
N1 GTR oil pump
N1 GTR water pump
Winged and baffled sump
RB26 head, throttle bodies and plenum
Head is ported and both manifolds are matched
(it flows 645 bhp on the flow bench at 2 bar vacuum)
Iskendarian valve springs
Titanium retainers
Tomei head gasket
Jun adjustable cam pulleys
Standard R32 GTR camshafts
I haven't run this one on the engine dyno yet, but it's sister (there are 5 in this batch) made 625 bhp at 7,250 rpm using Elf LMS. With upgraded camshafts and a GT35R, 700 bhp would be easily achievable. As for durability, the sister engine has completed a full season of racing (circuit and drags) and 6,000 k's of road work. It's leak down test is within 3% of when it was new, so another season is on the cards.
Does this sound like something you would be interested in duplicating? Depending on how much work you can do yourself and how many of the above parts are outside you requirements $9K should be doable.
Tick off the bits you need and I can tell you how much they will cost.
Hi guys, assembling the bottom end of an engine, bolting on the head and setting up tjhe camshafts is best left to someone who has the experience and the equipement. But that is less than 50% of the time it takes to assemble a complete engine. With a limited number of tools and experience many people can do the other 50%. Stuff like bolt on the oil pump, sump, water pump, cam tensioner and idler, flywheel. engine mounts, air con compressor, oil filter, turbo oil and water fittings, power steering pump, cambelt covers, coils, etc etc.
Saves money if you have the experience and tools.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
