not required...they dont drain anything substancial...they actually vent the sump on big clearanced race engines. On a properly built street engine they are waste of money, time and damage to firewall.
Notice two fuel rails on the picture supplied in post #2 (it was from another thread that i posted this picture in) Its a big $$ big clearanced racing engine.
so n1 pump, tomei oil restricter, 8ltr sump with baffle is enough?
i used to run N1 pump, tomei restrictor and stock sump with Tomei baffle 1 litre over filled.
never had an oil control problem and bearings were as good as new on pulldown after 3 years of racing.
Be specific Paul. "racing" Drag racing or circuit racing. Both disciplines require minute attention to the oiling system but curcuit racing adds other factors over and above what 1/4 mile work has to deal with.
Opinion is divided as to wether the drain back is a worthwhile mod or just a waste of time. The only definite in this whole debate is that it certainly wont do any harm by being there.
With that in mind I am more than happy to use it just on suspicion. It costs bugger all in the grand scheme of a build and, If the pro's are right it may save an engine.
Good enough for me.
Good enough for me.
great point for so little that extra insurance of doing it maybe worth it.
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
