Item: 1993 model R33 gts-t turbo, manual, gunmetal, Tein HA coilovers, Hybrid intercooler, ceramic clutch, HKS super dragger exhaust, apexi boost gauge, HKS turbo timer, very clean interior. Dent on left rear quarter from ute reversing into side. Quoted $1000 to fix.
Item Condition: Mechanically excellent, mint interior, exterior also great other than the bonnet and front bar needing a fresh coat, and the dent fixed.
Reason for Selling: Have new car, and no space to store this one. NO SWAPS, ALREADY HAVE NEW CAR!
Price and Payment Conditions: $7000 firm. These are going for $10-12K with these mods.
Extra Info: Always run on BP ultimate, just had service. Mechanically excellent. Everything works!
Contact Details: 0409 583 183
Pictures:
post-40613-1234098098_thumb.jpg post-40613-1234098109_thumb.jpg post-40613-1234098119_thumb.jpg
https://www.sau.com.au/forums/topic/256136-cheap-r33-gtst-manual/
Thanks mate! Im really surprised noone has snapped it up yet, its pretty cheap!
hi only have access to six grand at least till the next pay in 2 weeks, (will have like 6900 then but i think i can borrow the diff) would love to fly up from Sydney and drive it home this wknd though!
Im looking for an affordable track/daily and this looks like a great example, the dent sticker even looks cool!
patrick
patrick
Hey mate, this would be great for a track car with a bit of weight reduction. Its already got the suspension and exhaust work done! It would make it down to sydney without any problems too.
There is another guy who is keen to put money down within the next week or so, so if you want me to hold it, will need a deposit.
Give me a call if you want to talk about it, I only check this about once a week.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
