Hey guys,
i might be scoring dads unused Supercharger for the Z...
just wondered what mods i need to run 5-6psi boost on stock engine with a intercooler.
i aint to sure what the stock injectors/fuel pump can handle/ what the ecu can do as in being tuned...
;) thanks
https://www.sau.com.au/forums/topic/256506-supercharging-a-350z/
Mr Gazza, As part of the HKS kit, both the fuel pump and injectors are upgraded, as there isn't much additional headroom in them. You'll also need something to control the fuel/timing as the stock computer won't handle the changes well.
vq35 vipec's plug ins are in development , v88 wire in would work right now although you would be the test guinea pig to calibrate the drive by wire (or ditch it) . stock ecu remains to talk to the bcm to control all non engine car functions .
be wary of the supercharged stock internal vq , they make a bucketload of low down torque even at small boost and are prone to hurting rods . even a basic rebuild with some forged stuff might be a good idea if for longevity if nothing else.
will be an awesome engine though , so responsive .
Edited by autoworx
Hey guys,
yeah i wont be aiming for high hp, just enuff to piss on 6-7litres common-dores.
I've raced this dude in a yellow VZ 6litre HSV 307kw with a bucket load of mods, i had him by a few feet both on the lights and rolling pulls!
:) think i'd be happy with 5psi
i been reading stuff like this... which makes me think you can just bolt it on pretty much?
Yeah i'll call C-red n that see what they can do / reccomend.
Still open to ideas ect.
_______________________________________
Manufacturer: Stillen
Manufacturer's Web Site: Here
Type of Supercharger: Twin-screw
Additional Modifications Required: New hood that will clear the supercharger. These are offered by Stillen as well as other companies.
Price:
Stage 1 - $3,795.00
Stage 2 - $5,239.00
Stage 3 (Pulley Only) - $89.00
Stage 4 - $849.00.
Approximate Installation Time: 10-12 hours.
Future Plans: Stillen is reportedly developing a larger blower. They are being tight-lipped about it, but I was told it will work with the same hoods that work for stages 1-4 and most of the Stage 4 components. I would say it will have to be an M90. It will probably also have a larger intercooler. All of this will bump up the power quite a bit. The new upgrades are expected to be completed by the end of 2006.
There are 4 stages:
http://www.stillen.com/superchargers..._Guide_USA.pdf
Stage 1: This stage features the base supercharger with 6psi of boost. It includes everything needed for installation.
Stage 2:This stage features the base with 6psi, and it adds an intercooler as well as a heat exchanger with a coolant pump (with its own coolant) placed underneath the superchargerand.
Stage 3: This stage replaces the base pulley with a small pulley that increases boost to 7psi.
Stage 4: This stage features a new fuel pump, a larger 7th fuel injector, smaller pulley and remapped FMU (Fuel Management Unit) which increases boost to 8.5psi.
Mr Gazza, I personally wouldn't rely on what Stillen post on the internet, go talk to one of the tuning shops that have supercharged a Zed (C-red or Xspeed) and they'll have alot more useful info of what is required. I agree with Autoworx that the VQ35 isn't a strong internal engine, unlike the VQ30, so don't chsae too much power.
Cheers
Paul
With the HKS S/C on my V35 it was good enough for 312rwhp on only 6psi boost.
Internals were fine for street use.
Same power and less weight than a HSV you do the math :-)
S/C less likely to harm rods than a turbo setup
Edited by R34
:D Thanks all so far for your input, more is still welcome!!
Hey Chris, so u have you Supercharged yours / or someones 350z?
I just really want to know if all the stock stuff will be okay 'ecu/fuel pump/injectors' and can the stock ecu be tuned? i cant seem to find anything.
But i am calling C-red tommorw, i had to get valentine stuff today so had no time!!
And guys as i have stated a few times, i dont want 1000000 RWHP or my rods ect getting thrown through and out the side of block LOL !!
Its pretty quick as it is and most things cant beat me.
I just want it for a bit more power / BOV and yeah cause i can :)
i was going to go the same way, to supercharge the v35 but got quote 14k (including labour cost etc) and this was through with vortech. one of the members JaiK before had one for sale and it seemed mint so i wanted to do what he did. he managed 360hp and 1/4 was under 13s. he did his at c.red.
but in the end...i spent the money buying another car :(
i'd rather turbos bro coz they force induct and hold boost on, but lots more work involved aswell as cash aswell... s/charger is bolt easy induction mod really... takes few % of power you gain coz the pulleys n that!
still deciding and getting ideas myself
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
