Hey guys,
i might be scoring dads unused Supercharger for the Z...
just wondered what mods i need to run 5-6psi boost on stock engine with a intercooler.
i aint to sure what the stock injectors/fuel pump can handle/ what the ecu can do as in being tuned...
;) thanks
https://www.sau.com.au/forums/topic/256506-supercharging-a-350z/
Mr Gazza, As part of the HKS kit, both the fuel pump and injectors are upgraded, as there isn't much additional headroom in them. You'll also need something to control the fuel/timing as the stock computer won't handle the changes well.
vq35 vipec's plug ins are in development , v88 wire in would work right now although you would be the test guinea pig to calibrate the drive by wire (or ditch it) . stock ecu remains to talk to the bcm to control all non engine car functions .
be wary of the supercharged stock internal vq , they make a bucketload of low down torque even at small boost and are prone to hurting rods . even a basic rebuild with some forged stuff might be a good idea if for longevity if nothing else.
will be an awesome engine though , so responsive .
Edited by autoworx
Hey guys,
yeah i wont be aiming for high hp, just enuff to piss on 6-7litres common-dores.
I've raced this dude in a yellow VZ 6litre HSV 307kw with a bucket load of mods, i had him by a few feet both on the lights and rolling pulls!
:) think i'd be happy with 5psi
i been reading stuff like this... which makes me think you can just bolt it on pretty much?
Yeah i'll call C-red n that see what they can do / reccomend.
Still open to ideas ect.
_______________________________________
Manufacturer: Stillen
Manufacturer's Web Site: Here
Type of Supercharger: Twin-screw
Additional Modifications Required: New hood that will clear the supercharger. These are offered by Stillen as well as other companies.
Price:
Stage 1 - $3,795.00
Stage 2 - $5,239.00
Stage 3 (Pulley Only) - $89.00
Stage 4 - $849.00.
Approximate Installation Time: 10-12 hours.
Future Plans: Stillen is reportedly developing a larger blower. They are being tight-lipped about it, but I was told it will work with the same hoods that work for stages 1-4 and most of the Stage 4 components. I would say it will have to be an M90. It will probably also have a larger intercooler. All of this will bump up the power quite a bit. The new upgrades are expected to be completed by the end of 2006.
There are 4 stages:
http://www.stillen.com/superchargers..._Guide_USA.pdf
Stage 1: This stage features the base supercharger with 6psi of boost. It includes everything needed for installation.
Stage 2:This stage features the base with 6psi, and it adds an intercooler as well as a heat exchanger with a coolant pump (with its own coolant) placed underneath the superchargerand.
Stage 3: This stage replaces the base pulley with a small pulley that increases boost to 7psi.
Stage 4: This stage features a new fuel pump, a larger 7th fuel injector, smaller pulley and remapped FMU (Fuel Management Unit) which increases boost to 8.5psi.
Mr Gazza, I personally wouldn't rely on what Stillen post on the internet, go talk to one of the tuning shops that have supercharged a Zed (C-red or Xspeed) and they'll have alot more useful info of what is required. I agree with Autoworx that the VQ35 isn't a strong internal engine, unlike the VQ30, so don't chsae too much power.
Cheers
Paul
With the HKS S/C on my V35 it was good enough for 312rwhp on only 6psi boost.
Internals were fine for street use.
Same power and less weight than a HSV you do the math :-)
S/C less likely to harm rods than a turbo setup
Edited by R34
:D Thanks all so far for your input, more is still welcome!!
Hey Chris, so u have you Supercharged yours / or someones 350z?
I just really want to know if all the stock stuff will be okay 'ecu/fuel pump/injectors' and can the stock ecu be tuned? i cant seem to find anything.
But i am calling C-red tommorw, i had to get valentine stuff today so had no time!!
And guys as i have stated a few times, i dont want 1000000 RWHP or my rods ect getting thrown through and out the side of block LOL !!
Its pretty quick as it is and most things cant beat me.
I just want it for a bit more power / BOV and yeah cause i can :)
i was going to go the same way, to supercharge the v35 but got quote 14k (including labour cost etc) and this was through with vortech. one of the members JaiK before had one for sale and it seemed mint so i wanted to do what he did. he managed 360hp and 1/4 was under 13s. he did his at c.red.
but in the end...i spent the money buying another car :(
i'd rather turbos bro coz they force induct and hold boost on, but lots more work involved aswell as cash aswell... s/charger is bolt easy induction mod really... takes few % of power you gain coz the pulleys n that!
still deciding and getting ideas myself
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
