hey all.
i'm new to owning a car with a mod or two
quick question about wheel size and passing rego
the V35 has stock 17's. i have 19's at the moment (bought that way)
in regards to rego, do i have to do anything??? its not for a while, but ive seen a few people say "i use the stocks for rego etc"
Thanks for any help.
matt
https://www.sau.com.au/forums/topic/256813-wheel-size-and-rego-question/
yup that sounds about right. =) im only using my standard 7 spokes black coated OEM rims.. im pretty happy with them on. the car is lowered 1.7 inches.. so kinda makes the wheels looks a little bigger. yeh tyres will always be bigger at rear since its rear wheel drive. specially we can choose and control our traction on the road. if youre really paranoid.. just out the OEM ones so 100% safe..
im from Sydney also, correct me if im wrong with what i said. i was not 100% sure..maybe what i shared was on the police's point of view when they pull you over and try to defect you, but 1 thing i definately know for sure is that in NSW the lowest or the safest you can drop your ride is 1.5 - 1.7 inches from original height. cheers.
The law states that the wheels cannot be more than 26mm (1") wider, and the track can only be 25mm wider as well. Any more requires an engineering cert.
No regulation on the diameter of the wheel, but the tyre wrapped around it cannot be more than 25mm wider than stock and within 15mm on either side of the stock diameter.
True the cops don't always know the rules, so feel free to print out and carry the RTA's Vehicle Standards Index 09: Guidelines for alternative wheels and tyres
Thanks all, i'm in sydney
and the car didnt come with the OEM wheels.
Should be safe for now :(
what wheels did it came with? hope not chromies lol!..
and cool which part of sydney are you from? did you buy your V35 from an importer?
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
