Hi guys,
I am intending to purchase 400R side skirts for my R33, but I noticed that there are some going around without the little vent thing in them, (i.e. without the cut outin the side skirt)
Are these also 400R side skirts, if so, where can I get my hands on some that don't have the cut out (saves me from having to fiberglass the one with the hole)?
Cheers
https://www.sau.com.au/forums/topic/256843-400r-side-skirts-help-needed/
Show some pics.. then we can look at what side skirts your talking about (might not even be 400r
If you go to the following link you will see them:
http://www.skylinesaustralia.com/forums/40...400R+sideskirts
As you can see the skirts on the white R33 don't have holes in them....
dont touch anything off ebay.
I would say that white 400r kit might have white mesh on there.
Having said that however i got some jun sides off ebay. They didnt have holes cut, the were broken and they were of real shit quality.
NEVER BUY A KIT FROM EBAY
^ worst advise ever
when u get it painted, ask the person to fill up the hole
Its not a big job but may cost a little extra
I will be painting and fitting them myself, it would just save me time not having to fibreglass it by getting it without the whole.
Thanks anyways lads.
the only reason I suggest mybodykits off ebay is because Ive bought quite a few things off him full kit m-sport r33/r32 gtr front bar/r33 trial front bar and they have been the best quality fibreglass I've used anyway its up to you..
Yes I did purchase them from him, good quality stuff I must say, feels very sturdy.
I fiberglassed the holes and painted them. Will post pics soon. job turned out well, would have saved me some time but not to fibre glass them.
:D
Should always pre fit body kits cause they rarely fit. You might get lucky but more then likely you may have to do some changes to get it to fit.
WHat sort of changes? WHy would painting it matter?
If you did have to make alterations, commen sense tells me that it would be on the edges or on the inside of the side skirt, why would you have to modify the outside of the skirt since it doesn't impeed on anything?
well if you had to modify the edges on top of the paint job it would be seen wouldnt it? In that case if you wanted it to look pro you would have to re do the paint.
Common sense would have told me to pre fit before paint but what ever you say.
And you'd modify edges on the top that don't touch anything because....??
as i said because it would be SEEN! When you open the door. Also what if you havent sanded it down enough and you close the door and it hits the skirt, then you will chip or remove a layer of paint/fibreglass.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
