  • Replies 43
k well i personally would buy brand new ones if i could afford them
If you get your discs skimmed then they're more likely to warp again quicker, because you've made them thinner they wont be able to handle the heat as easy, also if they fall below minimum thickness after skimming then you'll need to replace them
If your going to get 2nd hand ones then make sure they're well above the minimum thickness as they may end up needing a machine themselves
Are you actually getting a pulsation through your steering wheel when you pull up a little harder than usual?
Nath
Edited by TAKUSHI
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4425060
if your gunna buy buy new theres plenty of options for aftermarket discs as for machining any brake shop can do it either in house or know who to send it to
personally i find worn stock parts to be an excuse to upgrade to something better
slotted rotors and race pads yea
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4425928
im probebly going to ahve to uograde my brakes after i add a bigger turbo so im lookign for something just for the time being so buying brand new rotors seems to be a bit of a waste so im tossing up between skimming them or seconf hand for a couple of months. anyone got an diea of how much skimming costs
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426157
skimming 'if you can skim yours is a waste personally' + i think its about $100 to get skimmed! so, i'd get some DBA slotted there only few hundred for a pair... 'try supercheap/repco' and maybe you could just get the fronts first!?!? considering thats where majority of the braking
comes from
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426326
$18 ea to machine a rotor .. I have new DBA 4000 n 5000 series rotors instock .. Also have 33 GTR brembo upgrades for GTS-T :P
Nothing wrong with skimming rotors , i been doing it for 16yrs and havnt seen any thing that can back that claim of " warping easier " after maching
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426389
haha commodores and falcons do it all the time buddy
and just think about that for a sec, the discs are going to be thinner
therefore they cant handle as much heat as they could when they
were thicker, and yes that couple of mm does make the difference
otherwise they wouldnt have such a small margin of wear between
new and throw in the bin, i'd just go brand new or upgrade now
your car will then be ready for more power mods, if not then at least
you know you'll pull up sweet everytime haha
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426519
Umm, sorry, but your wrong, and obviously don't know much about brakes :D
Skimming is fine, but if you have the $$$ get new discs.
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426593
LOL I know commo n ford are bad , When BA was released i was doing 3 - 5 cars a day for local dealership (Ford Aus wty was paying us $200 per car to go n machine oncar ) One car had 4000ks on clock when it was first done ( was only issue on base model brakes n not the premium packages ) , EL - EF have instructions on how to fit seals because if fitted incorrectly it will cause pulsating pedal after few thoasand ks and as for holdens i do average of 5 a week for pulsating pedal .. Have done new Pajeros at 1000 -5000ks old for mits dealer aswell
My GQ wagon is over 2 tonne ( close to 5tonne when loaded with race car n spares) and rotors 19mm thick and has done over 100,000ks since rotors were machined n pads fitted with no sign of pulsating pedal yet im doing commos at 4-60 thousand ks that have been machined ever n rotor thickness of 25mm :D
Also we had letter from holden saying that doing wheels up could cause them to pulsate and ford gave me a 5 page booklet on how to remove n refit calipers n rotors to try n prevent pulsting problems :( what a joke
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426624
i know plenty mate, im saying a brand new disc will last longer than a disc thats been skimmed, we've had plenty of customers come in after having other places skim discs and what you they're warped again and pal as for me refering to commodores and falcons, brakes are brakes dude, it all comes down to brand of disc and driver that determines the life of a disc, just coz they're all autos
Gwp021 just save yourself the hassle and go buy new rotors, coz if you're going to spend money on oomph you wanna know you'll stop fine, its called piece of mind
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426737
surprisingly when we skim the rotors and when they come in for their next service, i noticed their rotors needed machining again cause its heavily scored and pulsates everytime i brake and its been done on their last service as well which was like 1 or 2 months ago (the skimming was done properly too and they are not warped). we measure the disc on every services and yeh almost every commodore or falcon we get either needs their rotors machined or replaced.
Edited by R33_NICK
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4426833
hey guys just wondering if anyone knows where and how much to get my front rotors skimmed or am i better off buying a secondhand rotors
thanks
OK try PERTH BRAKE PART`S in welshpool & have them GROUND ,you should pay about $80 to $100,but it is worth while,
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4427101
Takushi, That's not what you said, but whatever.
sx, In summary: skimming is cheap, but is only an option if you have enough material left, otherwise new rotors are on the cards.
haha oh really??
aaand you still manage to repeat what ive already told him
68*** posts and counting....4 yrs of experience as a mechanic and counting
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4427454
um i may not have been clear i am running new rotors ( top level RDA's with braided lines and yellow stuff pads) cause i wanted to know my car could stop right specially with the comp racing i do
what i was trying to point out was that if the choice was made not to machine but to buy personally i'd choose to avoid the issue of using older worn discs that'd probably need machining soon anyhow and buy new
and honestly with what nissan charges it's really worth looking at aftermarket products
cheers
GWP
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4427474
A. TAKUSHI, why did you quote yourself? (Twice)
B. I'm not going to theorise on the implications of skimming brakes, because theorising has already been done...
C. From my 1st hand experience, when i imported my car i was told "all of your rotors need to be skimmed", 3 years later... same rotors, same pads, no skimming, still going (40,000kms.)
Anyway, if skimming was sooooo bad, why would it be an option?
Edited by Tezzah
https://www.sau.com.au/forums/topic/256959-r33-rotors/#findComment-4427476
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
