Hey guys,
Got a Garret 3071 Turbo with RB housing, spacer plate and lines. Done approx 3000k's. Made 280rwkw on a 34 GTT. Good for upto 28psi.
$2100
6x Sard 800cc Injectors to suit R34 GTT done 3000k's
$1000
Would rather sell local, but can ship at buyers expense.
Cheers Luke
Hey mate, Its water and oil cooled and comes with both lines. No shaft play. On 18psi it made 280rwkw. On 15psi it made 240rwkw. Starts spooling up around 3000rpm and comes on hard at 3500rpm and goes all through the rev range.
Edited by Luke_ENR34
***********UPDATE*************
Took the injectors out of the car and realised they are BOSCH 870cc INJECTORS, got sold the wrong ones in the first place :thumbsup:
So now they are For sale for $750
Sorry about the mishap.
Luke
  • 2 months later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
