have they made a nest in your car or are they just going walk about? A glass cup with a splash of coke or soemthing sweet seems to work for me. i have a drink, put the cup down, go outside to do some thing and when i come back its filled with ants that have been crawling around previously.
Just make sure you don't use diet coke :blush:
Not sure whether it's just an urbant myth or not, but aparrently the artifical sweetener aspartame kills ants.
The ants were like a conga line on the charger cable.............. I have a solution.
Ants do not like walking on rubber, i.e. they do not walk on rubber. They will not climb up your tyres, but they found the only other way into your car............ along the charger lead.
So: Wrap some rubber around the lead to block their path, or possibly sit the charger (and lead) on a rubber mat on the ground. No more ants!
Note..... must be rubber, not plastic and rubber mix, not nylon, not silicon, just rubber.
Good luck with it.
I'm guessing the ants are there because there must be a dead spider or some other insect (or even a small dead bird - I had one stuck in my radiator after a long trip :S ). The ants are just having a feast. Find the dead insect (or animal) and the ants will go away.
they're back.
unbelievable.
there is ant dust and spray everywhere now.
I've wrapped the power lead in an old bike inner tube (rubber) hope that deters them.
lol.. are they actually coming up from the ground still into your car or have they setup base in there somewhere...
who knows? it's mayhem in there...
now that I've put spray on the charger lead, the ones trying to get off the barge can't do so haha
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
