have they made a nest in your car or are they just going walk about? A glass cup with a splash of coke or soemthing sweet seems to work for me. i have a drink, put the cup down, go outside to do some thing and when i come back its filled with ants that have been crawling around previously.
Just make sure you don't use diet coke :blush:
Not sure whether it's just an urbant myth or not, but aparrently the artifical sweetener aspartame kills ants.
The ants were like a conga line on the charger cable.............. I have a solution.
Ants do not like walking on rubber, i.e. they do not walk on rubber. They will not climb up your tyres, but they found the only other way into your car............ along the charger lead.
So: Wrap some rubber around the lead to block their path, or possibly sit the charger (and lead) on a rubber mat on the ground. No more ants!
Note..... must be rubber, not plastic and rubber mix, not nylon, not silicon, just rubber.
Good luck with it.
I'm guessing the ants are there because there must be a dead spider or some other insect (or even a small dead bird - I had one stuck in my radiator after a long trip :S ). The ants are just having a feast. Find the dead insect (or animal) and the ants will go away.
they're back.
unbelievable.
there is ant dust and spray everywhere now.
I've wrapped the power lead in an old bike inner tube (rubber) hope that deters them.
lol.. are they actually coming up from the ground still into your car or have they setup base in there somewhere...
who knows? it's mayhem in there...
now that I've put spray on the charger lead, the ones trying to get off the barge can't do so haha
    • I like they don't raise their hands into the air when they shift their sequential boxes, seems to be a thing here in Australia lol...
    • I'm not normally one for posting random videos, but I thought we'd all appreciate the honesty about how broken our cars tend to be lol. Genuine skyline life here.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
