have they made a nest in your car or are they just going walk about? A glass cup with a splash of coke or soemthing sweet seems to work for me. i have a drink, put the cup down, go outside to do some thing and when i come back its filled with ants that have been crawling around previously.
Just make sure you don't use diet coke :blush:
Not sure whether it's just an urbant myth or not, but aparrently the artifical sweetener aspartame kills ants.
The ants were like a conga line on the charger cable.............. I have a solution.
Ants do not like walking on rubber, i.e. they do not walk on rubber. They will not climb up your tyres, but they found the only other way into your car............ along the charger lead.
So: Wrap some rubber around the lead to block their path, or possibly sit the charger (and lead) on a rubber mat on the ground. No more ants!
Note..... must be rubber, not plastic and rubber mix, not nylon, not silicon, just rubber.
Good luck with it.
I'm guessing the ants are there because there must be a dead spider or some other insect (or even a small dead bird - I had one stuck in my radiator after a long trip :S ). The ants are just having a feast. Find the dead insect (or animal) and the ants will go away.
they're back.
unbelievable.
there is ant dust and spray everywhere now.
I've wrapped the power lead in an old bike inner tube (rubber) hope that deters them.
lol.. are they actually coming up from the ground still into your car or have they setup base in there somewhere...
who knows? it's mayhem in there...
now that I've put spray on the charger lead, the ones trying to get off the barge can't do so haha
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
