yes but you could learn so i wont have to then you can be like the sauwa fixeruperer =P. that ebay one looks like fibre glass.. anyway to strengthen it like maybe putting some plastic or metal brackets in there?
https://www.sau.com.au/forums/topic/257778-34gtr-wing/#findComment-4437181
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
