in skylines, the radiator cap is lower than other parts of the cooling system, hey do this so the front of the car can be lower.. that is why you need to bleed the air out of the bleeder in the inlet manifold..
the breather tank moves the cap higher than everything else.. so if you mount it on the strut tower, with the second cap above the engine, it now becomes the highest point and all the air in the system will gather there, allowing you to easily bleed the air from the system by simply running the engine and filling it up..
rb's if not bled properly will gather air in the cylinder head as its higher than the radiator and the cyl head temps will get high and cause damage also the pressure of the cooling system will be low and it will do bugger all.. so its important to bleed them. breather tanks are better value for money than catch cans if you ask me.
cheers
Linton
so with the breather tank u dont need a bleed bolt no more as i remove it when putting greddy intake on my car and the realised thati cant bleed air for cooling system so with the breather tank i can bleed the air out
thank heaps mate
how do u hook a breather tank up the right way as its in japanense
im assuming that the bleeder has a radiator cap on top.. what has come in the kit??
most of them have a t piece that plumbs into a coolant line, or the coolant line gets replaced by the lines and bleeder tank.. just like a catch can arrangement but with coolant instead of blowby.
here is a couple pics of what it come with i think i need to buy the big split in the bottom rad hose
The picture looks like it explains it. Yes you need to get a tee for the bottom radiator hose. You can buy these for water temp sensors. You will then need to get a nipple that screws into it to attach a hose to. The top end looks like it sits between the over flow bottle and the radiator. the highest to the overflow bottle the lowest to the radiator. The other one can be capped off. Just make sure that you mount the top of it higher than the cap of the radiator so the air rises to the breather tank.
that is how i trought it would go just wanted to make sure
it has to sit higher then any coolant running around right so the dose that mean it has to be higher then the coolant line it the top of the turbo has i have a hi mount
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
