Hi All,
Well its almost been a year of owning my stag. About this time last year I was hassling Mcnamg for pictures and info of his stag, via PM. I've loved owning the Stagea so much and have made many new friends and gained alot of knowledge on working on cars. First time I ever worked on a car was on the stagea and that was changing the timing belt! and doing 100k service! If your wondering. No this isn't going its time to sell ect ect! The next year will be a bit tighter with cash though as Im going to be a Uni student and not working full time.
'97 s1 silver rsfour, leather, No Spoiler :blink:
In the year I've owned the car ive made the following mods (all i can remember):
  • SAFC2
  • Greedy Profec B spec II
  • Apeix Pod filter
  • Cold air box and Cold air feed
  • Gab Wagon adjusrtable suspension (also tried ohlins)
  • 18" racing hearts
  • Adjustable camber arms
  • Adjustable toe arms
  • 3 1/4" cat back zhorst
  • Hi-flow cat
  • S2 tail lights
  • earthing kit
  • voltage stabliliser
  • HID lights
  • Front Mount IC
  • PWR trans cooler
  • Timer built into alarm
  • Lucas premium front pads
Before I got the car glen had done:
  • Splitfire Coilpacks
  • .8mm gapped platinum plugs
  • clear front and side indicators
  • Alpine headunit and splits
Does anyone have any mods or recommend i do anything in the next few weeks while im still making good $$$. Thinking maybe a gbox service and a shift kit?
https://www.sau.com.au/forums/topic/258240-its-almost-been-a-year/
i think your pritty much spot on with a shift kit, if your retaining the auto. the only other things left are a turbo upgrade, abit more involved ecu/piggyback like an EMU, or a manual converstion.
id also look at doing the fuel pump, the one you have is +10yr old. also an ajustable cam gear may give you a gain but there are other things i'd look at first.
i've heard the walbro 500hp intank ones are good unit, apparently there were some dodgy ebay ones getting around prone to failure but if you get one from a site sponser they are ok. you can get the kit for around $195. im looking into getting a new pump soon aswell.
DUMP FRONT IS THE BEST MOD YOU CAN DO and a highflow cat
JJR stainless dump/front heat wrapped and a catco 3" cat
picked up so much response and midrange, standard dump is almost flat over the wastegate area :thumbsup:
i agree. it just helps the engine and turbo breathe so much more. you can feel staight away how much better the car goes with them.
Just got a qoute on a shift kit, looking at $450 drive in drive out.
Funny you say that. Did the dump/front on a mates and he said he noticed the catback alot more. :S
i did do my cat too...
its a different sort of change, eg, when it coasts for longer when you lift off, less throttle to maintain speed on the fwy, builds boost quicker on the fwy
i then felt a little loss of response when i did my FMIC
upping the boost when i have the motivation to install my EBC.
FWIW I paid 395 drive in/out for my shift kit
ah Im going to grab a cheap $40 adjustable one (s13) and drill the ring connectors to suit :D
fmic looks funneh, should photo it.... no camera tho, soz. sitting under the reo bar - big :) no more spotties and cut the bottom dayz lip off ooops
camera phone and MMS to your e-mail addy
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
