Hi All,
Well its almost been a year of owning my stag. About this time last year I was hassling Mcnamg for pictures and info of his stag, via PM. I've loved owning the Stagea so much and have made many new friends and gained alot of knowledge on working on cars. First time I ever worked on a car was on the stagea and that was changing the timing belt! and doing 100k service! If your wondering. No this isn't going its time to sell ect ect! The next year will be a bit tighter with cash though as Im going to be a Uni student and not working full time.
'97 s1 silver rsfour, leather, No Spoiler :blink:
In the year I've owned the car ive made the following mods (all i can remember):
  • SAFC2
  • Greedy Profec B spec II
  • Apeix Pod filter
  • Cold air box and Cold air feed
  • Gab Wagon adjusrtable suspension (also tried ohlins)
  • 18" racing hearts
  • Adjustable camber arms
  • Adjustable toe arms
  • 3 1/4" cat back zhorst
  • Hi-flow cat
  • S2 tail lights
  • earthing kit
  • voltage stabliliser
  • HID lights
  • Front Mount IC
  • PWR trans cooler
  • Timer built into alarm
  • Lucas premium front pads
Before I got the car glen had done:
  • Splitfire Coilpacks
  • .8mm gapped platinum plugs
  • clear front and side indicators
  • Alpine headunit and splits
Does anyone have any mods or recommend i do anything in the next few weeks while im still making good $$$. Thinking maybe a gbox service and a shift kit?
https://www.sau.com.au/forums/topic/258240-its-almost-been-a-year/
i think your pritty much spot on with a shift kit, if your retaining the auto. the only other things left are a turbo upgrade, abit more involved ecu/piggyback like an EMU, or a manual converstion.
id also look at doing the fuel pump, the one you have is +10yr old. also an ajustable cam gear may give you a gain but there are other things i'd look at first.
i've heard the walbro 500hp intank ones are good unit, apparently there were some dodgy ebay ones getting around prone to failure but if you get one from a site sponser they are ok. you can get the kit for around $195. im looking into getting a new pump soon aswell.
DUMP FRONT IS THE BEST MOD YOU CAN DO and a highflow cat
JJR stainless dump/front heat wrapped and a catco 3" cat
picked up so much response and midrange, standard dump is almost flat over the wastegate area :thumbsup:
i agree. it just helps the engine and turbo breathe so much more. you can feel staight away how much better the car goes with them.
Just got a qoute on a shift kit, looking at $450 drive in drive out.
Funny you say that. Did the dump/front on a mates and he said he noticed the catback alot more. :S
i did do my cat too...
its a different sort of change, eg, when it coasts for longer when you lift off, less throttle to maintain speed on the fwy, builds boost quicker on the fwy
i then felt a little loss of response when i did my FMIC
upping the boost when i have the motivation to install my EBC.
FWIW I paid 395 drive in/out for my shift kit
ah Im going to grab a cheap $40 adjustable one (s13) and drill the ring connectors to suit :D
fmic looks funneh, should photo it.... no camera tho, soz. sitting under the reo bar - big :) no more spotties and cut the bottom dayz lip off ooops
camera phone and MMS to your e-mail addy
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
