soo i have a rb20det automtic transmission and all of the other auto crap to go with it
transmission is in perfect working order
located in adelaide
just pm if interested,
cheers
jason
Edited by i eat dirt
https://www.sau.com.au/forums/topic/258461-rb20det-auto/
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
