You must have had your baseball cap on backwards-sideways or some other blatant hoon behaviour.
Fight the powers!, I hope the judge gives the cop a serve for clogging the legal system with such frivolous crap.
What a joke.
i also said sorry for taking the courts time for such a small matter - the judge seemed to appreciate that
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4463657
  • Replies 66
to the police members on here ...............................
why is it that every ford focus barina etc that live in my local area that i see every day
have bald front tires and are clearly unsafe never ever get done like this?
I'm not a cop but I'll answer that.........it's called "Discrimination".
PS Well done for fighting the charge.
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4467047
because our cars attract attention. and becuase half the skyling drivers in the world are wankers that drift and skid on public streets?
it's shit, but it's easy to see how the stereotype came about. and let's face it. 4/5 imports pulled over are probably defectable.
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4474938
The other scam they pull is not having a spare tyre in the vehicle.... They tryed to pull that on me. I explained to them that I would take the fine and see them in court explaining to them that it is not a defect and they should pull over the new BMW's, Merc's and VW's as they come with a can of spray as the spare or a flat tyre straight tyre out of the factory....If you have a spare it must have legal tread (doesn't have to be pumped up) if there is no spare they cannot do a thing... Helps when you worked in the industry....They decided not to give me the fine and did a RBT instead funny that.....
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4476117
talk to your lawyer, thats what you've paid him for.
I have never been to court before, but presumably whenever you were going to ask for another 2 weeks, just say something like "the police have failed to provide me with the documents that I have requested and am legally entitled to and as such has wasted another one of my days, and more of the courts time. I wish to ask for the case to be dismissed so I dont have to waste more of the courts time in dealing with a bogus offense."
again, talk to your lawyer - i may have it all wrong ^_^
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485319
ok good info
ill try bring this up in the morning
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485651
Thanks matey
Unless you kick your lawyer in the arse and get him moving he will be quite happy to drag it out as long as the cops want to. Remember, He gets paid every time he does something on your behalf.
he may have you convinced that hes on your side but believe me, He isnt. He is on his side.
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485713
oh nice
my lawyers ok
he advised me he doesent have to attend to adjournments to save me $$$
but i dont mind spending the money to see how this all pans out
it will be good for all of us to take a look at the system and decide if it will be worth fighting that misinformed bigot cop
https://www.sau.com.au/forums/topic/258570-defected/page/3/#findComment-4485863
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
