Hey,
Just bought a R34 Bomex kit to make fit my R33. I know i need R34 front blinkers but am unsure where i can buy the fitting for the bulb and wiring from? any ideas anyone? i dont think a wreckers would be to happy to cut up a loom to provide them.
Any help would be appreciated.
https://www.sau.com.au/forums/topic/258616-r34-front-indicators/
lol everyone loves copying me doing the r34 bomex to fit the 33.. i believe i was like the first to do that bout 3 and abit years ago now.. my first car and first riced out skoiloiner bahah
I actually hadnt seen it done before i found the kit cheap on ebay and had a conversation with Blitz bodykits about modifying it to fit. I was looking for an R33 bomex kit however i couldnt find the replacement front bar to the one I had.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
