Hi everyone, i've recently been looking into where i can get a rear strut brace for my C34 stagea from, i know there are a couple of other people on here interested in them as well so this is what i've found.
I've contacted a couple of the site traders with little luck. One site trader said that they can get a stagea specific Cusco item for $335 plus postage and handling to your address. (PM me if you want to know who). I've had a look on yahoo auctions and found them for $380 pph. Also found some places overseas, NZ and USA that can get them but it still works out to be over $300 after postage.
Can anyone shed a little light on where else to get one from? i think the exchange rate at the moment is going to be a big downside for anything coming from japan, and from what i've seen there isn't much change in the price between the places that can get one.
Or alternatively, has anyone successfull fitted a rear brace from another car? little modification eg redrilling mounting holes, is ok.
Something else i found out is, all the C34 stageas, S1, S2, 4WD, 2WD, Autech, Auto, Manual, etc,etc all have the same part number for the rear strut brace in the Cusco catalog. its just the fronts that vary.
https://www.sau.com.au/forums/topic/258793-rear-strut-brace/
mine is "Carbing" branded: probably the chunkiest/thickest one I have seen. It is a very good quality item. Hope that helps, guys... I got mine secondhand over here, so I will be no help with sourcing one.
also, if you're not fussy on bar thickness/design then you can get the cusco AS style brace slightly cheaper than the OS model
yeah i've seen this one. it works out to be only about $30-$40 cheaper than the OS type. IMO the OS type looks alot better than the AS type, also the OS appears to be a bit more rigid.
I would certainly be interested in one if a Group Buy goes ahead. QWK32 you should setup an EOI so that you can get a feel for the numbers, I am sure if we can get at least 10 people then any trader would be happy to give us a discount of sorts maybe 10% :( .
Imo I think the OS strut brace would be the way to go, if your gonna do it might as well do it right and the arse end of the stagea needs quite alot of strengthening across the middle. Strapping a good looking pipecleaner across might look good but I would be dubious about how much additional briacing it would provide.
For future reference:
Cusco: http://www.rhdjapan.com/jdm-low/Cusco-Alum...ar-Type-OS-9597 360delivered (on the 27/2/09)
Greddy: http://www.rhdjapan.com/jdm-low/TRUST-GRed...Strut-Bar-11320 290delivered (on the 27/2/09)
You are viewing a Trust Greddy Aluminum triple tube Rear strut bar. Due to the triple tube design they are more rigid than the Cusco (only twin tube) units that we have for sale as well. The Greddy imprint in the bar is very attractive and bold. It is the only bar that dares to put its brand name right up under the hood and in your face. Only Trust Greddy, no other!
Edited by Ryan1600
Hey guys, sorry I only just checked my PM's. 'QWK32' Has PMed me about getting a few of the guys together and maybe doing a group buy.
Getting them is no problem,but go through the traders first and see what they can do.
For me to do it, it will take anywhere upto 18 days for delivery as im back at uni this coming week and need to put study first. Please note im not a trader, I only got the last set for a mate and simply made the offer for others who couldnt find them.
can you beat the RHD price for the Greddy?
Just looking at both those bars. it appears they have different mounting holes. Will they both fit?
The cusco one would look neater cos the tabs come out to the side rather than straight up like the Greddy one. Wouldn't it?
Anyone have photos of an installed Greddy rear strut bar?
have a look at Chooks post in this thred, it has a link that shows pics of the Greddy bar installed, looks real nice.
i would go off the pics on the RHD website as a referance to the actual stagea item, as on the same page other cars are also listed.
ok, i've got a few replys back from some of the traders and other people that are able to source these bars. so far it looks like all options are going to be around the $300 mark. i haven't got time to post them all up at the moment but i would like to know how many people a genuinely interested in getting on of these.
the two i've got prices for are the Greddy one and the Cusco OS type.
i'll be back on later with a few details.
i will be going a greddy as RHD think they are stiffer
they use generic photos for all models, keep that in mind. specify model when ordering, and when ordering endless pads u normall give your VIN or month/year build date.
-Ryan
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
