  • Replies 881
Ah, the good old days :blink:
Was more of an 'enclosed' area...
I dunno about anyone else but the only reason I stopped going was cause of the ciggy smokers lighting up in there....
Fair enuff u wanna smoke, but nicotine makes you smell like an ogres anus... not into that thx ;)
-D
News from Villi's: The outdoor area is going to be revamped and turned into an indoors area as part of the cafe. A new outdoors area is being built closer to the loading dock area. Bigger toilet area and a store room are going in where the driveway goes into the building.
you have vilis connections do you? ask them for a flat screen tele with some sports running :)
Nah i wish Dan, and if idid i'd be the size of a house!
Just overheard a guy there on friday night before Chad turned up. Nearly fell of the chair too when i heard how much they rake in from the Clipsal! :)
