  • Replies 881
lol, that dude come over to where i was with my patrol mates (one of them is a security guard at a few venues around town) and he knows him from vodka bar. apparently he gets a bit angry on occasion
ended up goin via the land of promise (as matt had to do some work down there), then jon and myself lapped town. got to see 50 odd people punching on as we drove past the woolshed haha
umm interesting now...getting kicked out of BP
Ha. I recall a year or two ago, the BP had a security guard who stood out front. Tried to get the bikers to move on. At that time they were trying to enforce a 30 minute maximum parking time. We argued it wasn't acceptable, because we were patrons, and to shoo us on in 30 minutes when we needed time to refuel, eat and drink. And they did not have signage in place to advise of the parking limits anyway.
Their next strategy was to close the public toilets. But that was illegal and we pointed that one out. Facilities must be made available to the patrons during full opening hours.
Must just be a BP thing :P Some dude at the Port Wakefield BP was complaining about Troy's car being parked at a pump ... when he was in the line to pay for fuel. The same dude just minutes later was parked in front of the automatic doors, next to my Stag (parked legally). :P When we left the BP I blew the guy a kiss. :down:
Edited by RubyRS4
So the question is, will you still go there after Vilis? Or is it time for a new venue?
As long as my biker mates still go there, then so shall I. We've been attending BP for over 8 years now and we haven't left yet. Its central, and its convenient ... and provides for good laughs at the wide variety of 'types' that go thru there. :P
BP should at least respect the BLUE MESH.....:P
I will most likely still go to BP what they going to do....as long as we keep buying something from there they cant tell us to move on really
well...if you guys want a run down south..i'll be fitting my turbs,doing my brakes and servicing the trans if ya's wanna do a fly by or even pop in to dribble shit...i'll be surounded by dattos as well...mainly 1600's
4 wagons and 1 sedan in the shed...occupying space with a 1200 sedan and a shitter fairlady...1 sedan outside occupying space wit a shitter exa turbo and a kitted honda which got reversed into....1 wagon is relatively drool worthy...other one is waiting for a s15 sr20 conversion to be finished...others are projects that havent even started...all up at pauls shed
Who is planning on coming to Villis tonight?...cos i am
I should be. I'll have the lad with me, plus I've got some running around to do beforehand ... like getting another bumper for the 33.
Ahh Cam he can tell us more jokes :blink:
or he can tell us more about zombies
as previously stated...i'll be giving my 31 an early 21st birthday pressie tonight up the end of panalatinga road..onkaparinga hills.....hopefully it wont be too cold
have fun with that, that road would have to be one of the smoothest i have seen in the south...actually in all of adelaide.
