The final results are that it's in and working - on zero degrees :) The reason being that when I tried -3 and -4 degrees, I got a noticable drop in power. I also got the maximum injector warning on my PowerFC hand controller, so it could just be because I don't have enough fuel for the extra power. But it also could just be that the timing is so adversely affected that I'm just maxing out the injectors and losing power at the same time.
So I put it back to zero degrees and it now awaits a tune. I am waiting for my Z32 AFM to arrive from Germany, and I will then put that in along with my 550cc injectors, and then get the workshop to set the gear to whatever works best. If it ends up on 0 degrees, I will remove it and put the factory one back in and sell the adjustable one.
  • Replies 126
Ok just put it on, now this is what i done, correct me if im wrong.
With no cam gear markings, only centre, the cam gear is 360 degrees, and has 48 teeth, so each teeth represents 7.5 degrees, so i adjusted it too half a tooth, say 3.75 degrees. I adjusted it clockwise. Does this sound right???
Now, looks like i have to get a new timing light as i can't connect anything to that white lead, but im getting a lot of ping, so im doing the old trick, advance until it pings, and then back it off slightly.
BAD BAD BAD..... For every 1 degree on the cam wheel, it's 2 degrees crank angle !!
So in my case I was aiming for 3 degrees crank angle retard, so I adjusted my cam gear to 1.5 degrees retard...
So if you adjusted yours to about 3.75 degrees on the cam gear then your running about 7 degrees retard !!!!
J
Do you guys have a dyno sheet of your cam gear installs? I had a flat power curve before I put mine on (no dyno sheet to post up of that sorry), but afterwards when I had it set to 4 degrees retarded I got a decent power dip when the NVCS kicks in and a stronger top end. Before the retardation, I couldn't feel the power dip, but now I can. If you look at my torque curve, it's not too impressive at all.
Here's my dyno sheet (big file, sorry) - http://members.ozemail.com.au/~caddies/MIC33Rdyno.JPG
So basically, I guess what I'm asking is, Were you guys able to tune the dip out with a decent ECU like a Power FC, and is it worth my while to remove the gear from my 33 with a Super AFC (where I feel it hurts the drivability) and put it into my future 34 with a Power FC? I was planning on selling it with the car.
Before you get a re-tune to try and get rid of the dip, change the cam gear to 3 degrees retard (1.5 degrees on the cam wheel) and see how that goes.
Generally (changes depending on setup), 4 degrees will give you more top end, while 3 degrees will give you more mid range.
I opted for 3 degrees cause mid range is where it's all at for me :D:D
Jay, I'll be selling the car soon, so I probably won't change the cam gear except to remove it (if it's worth keeping). If I wasn't selling it, I'd definitely do the 3 degree change.
I asked them about the dip when I first got it tuned, and they said it's a pretty standard graph for a car without an ECU that can control ignition timing. They said if I want to have it tuned out I'd need something like a Power FC.
So I'm just tossing up whether or not I should keep it for my next Skyline (which should be this year).
Hi MIC33R, when you retard the exhaust camshaft timing (with the adjustable pulley) you retard the base ignition timing as the CAS is connected to the exhaust cam. You then correct this by advancing the CAS in its slots. What the workshop told you is similar to our experiences, the retarded exhaust timing needs a bit more ignition advance to work best. This is particularly noticeable when the engine is building boost. Hence the dip in your power graph.
As for keeping the adjustable exhaust pulley when you sell the car. As I see it, the question is will you get more for the car with it or without it? And will the difference be enough to buy a new one for your next Skyline? Or will the cost of removing it out way the benefit?
Hi Lukits01, I use a marker pen and put a line where the bolts are in the CAS slots.
Hope that helps
Hi
G'day SydneyKid,
Just wondering if the change (retard) of timing, when you retard the cam gear, is noticable in a change of base timing with a timing light?
I'm just thinking that once the cam gear has been retarded, is it best to check the base timing and set it to what ever it was, or back to the stock 15 degrees advance, seems that if you line it back up with the mark you put on the CAS it'll now be a touch retarded.
Thanks
J
Thanks for the info Sydneykid. I feel it won't really add much to the value when I sell it, but the cost of paying someone else to take it out is fairly high and would probably be more than it would add to the price. I think if I removed it myself (which I am a little scared of doing), it would be worth it. It's something I'll have to think about.
MIC33R, I was scared of doing it myself too. Read back in this thread and see for yourself! But once I listened to enough advice about other people doing it, I decided to give it a go and I'm glad I did. Once you've done it for the first time, you should be able to do it again within half an hour if you want to swap back again for whatever reason.
Im quite confident now in doing it, the time consuming bit for me is getting the timing right, as i dont have the proper timing light gun, i have to go until it pings then retard it a little, although i think im nearly spot on.
is that the timing at the cam gear or at the CAS?
what was your final settings anyway?
Hi Jay95R33, I always check the ignition timing with a timing light and adjust accordingly. The marks on the CAS mount are only there as a point from which initialise the CAS adjustment. Otherwise, I have no idea where to start. I can also observe how much I have to rotate the CAS to get back to where I started from, from an ignition timing point of view. I have had occasions where this audit check shows up other issues (eg; worn locators in the CAS).
Hope that clarifies
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
