couple months ago i was driving my gtr and went round a corner dong about 25km in 2nd gear then the car started to splutter and died. turned it on, got it started but it sounded more like a v8, extremely chunky, rev'd it a bit but it wouldn't go over 2200rpm then just died. this morning i was having a look over it, checked all hoses and piping and thats all fine. got the car running again and it was still chunky and blowing a shit load of grey smoke. fuel pump engaged. I'm thinking that maybe my battery could be a bit dodgy because when i got it started power fc had reset itself and just before my car originally started to f**k up i hit a bump which i thought might have caused the battery to do somethin weird and cause the pfc to reset.
if anyone has any ideas please let me know. quite puzzled as to what it could be.
https://www.sau.com.au/forums/topic/259003-r32-gtr-rb26power-fc-problems/
it was in the car before it came to australia and as far as i know it was retuned before i bought it. yea i'll have another look at the intake piping but i was quite thurough.
that wont cause the pfc to reset where is ya hand controller any chance it was bouncing around? this happined to me abit back had it in the glove box it managed to bounce around pushing buttons and changed my afm to rb25's lol i have a gtr and it didnt like that at all wouldnt rev past 3,000 was like a rev limiter
i reset my pfc again and changed it all to the appropriate settings, r32 AFM's, boost controller kit off coz i got an avcr, etc things like that. got the car running, took it for a quick drive and as i hit about 2500rpm it was struggling. was popping alot and was about to die. possibly blown turbo? ran like a piece of shit.
w1632.png.
dont think my hand controller would be too succesful with bouncing around haha
Edited by gtrnismo
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
