i recently got a expensive good brand timing belt put on my car and my water pump done as well because it was making a fluttering noise and my mate said it might be the water pump & it sounded like it was screwed.
picked my car up and paid half the cash and started it up and the fluttering noise which was coming from where the water pump was heaps worse than normal so i got out and asked did you do my water pump and he said yeah and informed me cars make that noise after a while so i said how come all my mates with their skylines which are older models then mine don't make that noise?
he said he didn't know which i replied with a get f**ked you lazy bastard and he told me he wants the rest of the money.
the next day i started the car and its was screeching for like a minute stationary or if i accelerate forward it stops, noise was coming from where my new belt was.
it keeps doing this if the car sits there for like half a day and start it up.
the noise is like when you hear a guy start up a really old ford falcon and you hear it screeching when he drives off.
could it need tightening as its a brand new one?
im gonna see another mechanic my mates take their turbo cars to and if he says that the water pumps screwed that other mech is gonna hear about it and he better give my money back.
do you think it is a stuffed water pump for it to keep making a loud fluttering noise? it dont do it all the time but when it does its pretty load.
thanks guys.
https://www.sau.com.au/forums/topic/259016-brand-new-timing-belt/
alternator belt .
tension check by touch, if there is some give, its need tightening,
just had my 100,000k service done, pump and all belts, and plus there new, let them wear in, but also get them tightened. not to tight though, if you put to much strain on the alternator and can wear out the bearing at the back of the alternator i think, its connected to the pulley that spins it.
hope that helps, i get about 3seconds of screeching now, not 1min like before
thanks guys.
let me try undertand a little more......
did you take it to a dodgy mechanic? and was the water pump brand new???
well it sounds like it could be 2 things at this point.....the water pump pulley or the Engine crank pulley?
what happens if you have the bonnet open whilst revving?....does this happen or only when the engine is on a load?
i wouldnt be paying him anymore more money till this is sorted....
from what people have told me recently he's dodgy i wish i knew that before i seen him,people say they have asked for a oil change and spark plugs and he only changed the oil,reused the oil filter and when they checked the spark plugs they were putrid,a mate told me he needed new bearings in something cause they were making a noise,he paid for brand new ones and found out the guy greased up the old ones.
the thing is the prick never gives out receipts so there is no proof you even went to him.
i asked for a brand new water pump but i doubt he even did it,i asked him if it was a pulley but everytime
i brought the car to him it didn't make the noise cause it only does it every now & again.
as for the screeching today i started the car up to mow the lawn and it did it again even when i was driving it kept going then stopped,mowed the lawn started it to put it back and screeched again.
i have opened the bonnet when it screeched and it sounded in the area of the timing belt and it stopped after a bit,revved the car & sounded normal it only really happens when i start the car cause the car shudders like anything when i start it and the revs are real low like almost stalling then they go up to 2000rpm after 7 secs and when its warmed up stays at 1000rpm,i also told him about that as well and he said i don't know,f**k hes lazy.
it never use to do that until my mate took off the rocker covers to paint them yellow and he took off the plenum to clean it cause it was filthy,he put it back together now the revs are too high so i have no idea what he has done to it.
firstly, im sorry to hear of your misfortune.
what you've confused me again...is:
a dodgy mechanic did the timing belt...and did some sort of full service. and changed the water pump and supposedly regreased some bearings.
but you've told us that this was the cause.
though in your second post ...it may not be hes dodgy work but a "Friend" of yours...(im guessing who isnt the mechanic) removed the plenum, throttle body etc
and since he did that...thats the culprit?
its hard to say withought seeing, but can you get access to it?...open the cover and see if its over tightened...
a good way to tell if it is the pulley.. you use a rod or a long screwdriver..place it on the nut that pivots the pulley and put it against your ear to listen.
it should have a smooth even sound....
hmmmm
well did he clean the throttle body?..are you sure he knew what he was doing?...sometimes things can get jammed in it whilst cleaning, causing irregular idle. i would inspect everything again.
what does the idle on the RB25DET on your user handbook say?
and by the way...which mechanic is it?.....you may warn other fellow members to steer clear from this mechanic...
hmmmm
no,he didn't grease any bearings on my car it was another mates,all the mech did on my skyline was the timing belt and supposedly the water pump.
my mate did my rocker covers about a month before i got the timing belt done,yeah he took the rocker covers off and painted them and put in new spark plugs and we noticed the throttle body was putrid it was black with filth so he took off the throttle body and the plenum and the AAC valve and gave it a thorough clean with carby cleaner then degreaser and he put it back together.
the car was running smoother but then we noticed the revs were staying at 1200 rpm and my mate said not to worry about it.
some guys on here told me to turn the idle srew in and the revs are now at 1000rpm but before all this happened it sat on 850rpm.
the car does shudder alot when i start it up for the first time in the day and the revs stay really low around 400-450rpm like its gonna stall for a little while then it shoots up to 2200rpm then when it warms up sits on 1000rpm.
about a month later is when i got the the timing belt and water pump done.
im gonna go see the other mechanic tomorrow cause he wanted me to bring it in to have a look and i will tell him all the things that are wrong with it and hopefully he can fix it all,i will ask him to replace all the old belts and get him to take a look at the water pump while hes got the cover off.
yeah whatever my mate did is the culprit for the over revving,for all i know he stuffed the throttle body all he didnt put a gasket on properly.
mate, sounds like your mate damaged a gasket when doing the plenum stuff, if it leaks vac at idle you will be lossing boost and power up top.
if you remove the cam belt cover and look down in there you should be able to see if the water pump ins new and shiney.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
