ok so i just got a 32 m spec with the foloing mods
RB20DET
RB25 turbo
5spd manual
1.5 way viscous lsd
sunroof
electric windows & mirrors
FMIC w/ custom piping
Apexi pod filter
3" cat back exhaust
Exedy 5 puck brass button clutch
JIC coilovers w/ Tein springs
strut brace
Bosch 040 fuel pump
plus a few others
whats got me scratching my head is that when it comes on boost it seems to pull stronger when i'm at 2/3 or 3/4 throttle and if i nail it it makes the noises and sounds like its going hard but doesn't really seem to pull well at all
i am leaning to a problem with the tps as i've been having some idle problems and the aac is now squeeky clean
can someone please confirm the precedure for setting the idle on a 32, what i really want to know is if your supposed to unplug the tps as well as the aac connectors
if anyone has any ideas please put them up
Thanks
Tom
https://www.sau.com.au/forums/topic/259183-rb20-not-boosting-hard/
sorry was in a bit of a rush
dont know if there is supposed to be a comp controlled solenoid on the 32's but there is a pressure line running from the turbo outlet to the actuator and goes to about .7bar normally but i had a bit of a hoon yesterday to see whats what and looked down to see it saying .9
also the cat is gutted and it does backfire sometimes and sometimes stalls when clutching in to come to a stop
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
