Just wanted a quick check.
My friend got a c34 engine in his car. Its rb25det. Electronic vise its like early r33 engine. I didn't check the coilpacks though. CAS is mitsu, the TPS sensor is like on r32/early r33/rb26. But the ECU socket is gray like NEO engine, and consists of 3 plugs. Not like old nissans - blue plug/socket.
So my question is will I be able to get a NEO nistune board into that ECU and will it work ? Or ecu internals are like old r33 ?
Need some input.
Thanks!
wont work, buy the sounds of it he has the engine out of the S1 stagea, you can't install the nistune board on these. the ecu internals are like the R33 ecu's with an R34/S2 plug.
Have you asked Nistune...?
Or wait for Trent/Status/URAS too see this thread and be led to the sister thread in the Stagea section! http://www.skylinesaustralia.com/forums/Ni...63#entry4457563
As if it is do-able, that is who i will be seeing haha
r32 ecu +adjustable cam gears... or Z32 ECU, both work on r33's, so why not us? If a S2 ECU or R34 then that makes it less work as they atleast use the same plug bar some pinout variations on the 34...
Need some input.
Thanks!
I think you will find that the engine you have is the same as a 33 and i would assume the ecu would be the same, can be done, but for the money you are spending you could get a power fc instead, a lot of screwing around to get them to work.
Other options are to mod a Z32 ecu (there is one for sale in the for sale section) or use an R32, if you go an R32 you wont have vct.
I looked into it for a while and ended up going for a power fc.
I don't think they know
You dont know if you dont ask! Seriously send me an email through and I'll have a look into it. The main thing I would need from you is
(a) photo of the insides of the ECU so I can see what internal connectors (if any) there are)
(b) consult download of ROM image. You need a consult cable for this. Use trial version of Nistune with ER34 address file and do Operations-Consult Download
Email those through and then I can see if it runs. It most likely will since ER34/WC34 (stagea) are basically the same. From what I have observed so far C34 may be also... and I might be able to bench test the board in an ER34 on the bench too
  • 10 months later...
Hello guys what did you find out. I have the same issue myself right now. I wanted to get a Nistune setup but not sure if it will work on my board. Some suggested that since I still have my old z harness that I take the the blue end and rewire my c34 harness to match a normal R33 harness. So as we all know that is a lot of work but cheaper than buying a used harness for like 350. So your help would be greatly appreciated.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
