Hey guys,
I need a recommendation for a good alloy welder...hills area preffered (as the car is unregistered) - i need a crack welded up in the front of the block.
If i can get a quote..or if one of you guys can help me out that'd be awesome!!
I'm trying to sell it and thats holding me back!
Thanks in advance!!!
Nick
https://www.sau.com.au/forums/topic/259230-alloy-welders-weld-sr20-block/
what is the crack going to be subjected to?? coolant?? combustion etc?? very few people will be able to successfully weld it up if its wet.. they need to be completly dry and clean to weld.
you could try some devcon... i used it on my radiator for 4 months, its still holding, ive just replaced it since.
um... why the hell would he want to do that? ya freak.
coz its more reliable and easier to get higher power derrrr lol
also you don't get cracks in the block...
also its a skyline forum so most people on here are biassed towards it
hehehehe :)
so waht you're saying is because it's a skyline forum, they don't know any better?
that's all im hearing
(ps. I purposely ignored the comment on reliability as i have nothing to say on the topic for obvious reasons. Thanks for reading)
whats wrong with the sr20?? if i had time and fundage... id consider putting one in my 32... but i dont like engine swaps like that.. but imagine the lightweight engine... mounted as close to the firewall as possible, with a lowmount turbo..
the weight would be behind the front wheels and with the skyline chassis and double wishbone front end... it would be pretty good on the twisties.
and they sound tuff.
nothing like an rb though.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
