Hey guys, got a stack of magazines i don't read anymore (Hot4's, High performance imports, Autosalon, Speed, Fast fours, Zoom, Drift Battle etc) that are just sitting in my closet. 95% of them are in perfect/good condition.
Also got two model cars, One a muscle machines R34 GTR and the other, Paul Radisich's Year 2000 Shell Helix racing Falcon, Genuine and comes with Signed Certificate. Box is stuffed though. Both are 1/18 scale. $40 each Or nearest offer.
$100 ono for magazines. Location is South east Melbourne. Pickup only. Cheers.
Edited by lsk
https://www.sau.com.au/forums/topic/259273-magazines/
  • 3 weeks later...
Hey mate, just checked and organized them, i have the following:
High performance Imports: 42
Hot 4s: 82
Zoom: 10
Speed:6
Fast fours: 29
Autosalon:49
So all up, 218 magazines (there are a few doubles in each). If your still interested, ill sell the lot for $150. I will upload pics shortly (sucks being capped).
Cheers.
Edited by lsk
https://www.sau.com.au/forums/topic/259273-magazines/#findComment-4505156
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
