Ok, Friday before last I took off from work and gave it a bit of boot from a standstill, the clutch woudn't disengage. I managed to baby it home and a few days later got the gearbox off and found the clutch plate had stuck/semi melted to the flywheel. See pics of worst puk and friction material left on flywheel.
I sent the clutch away to be looked at by exedy and they basically said it's not a warranty issue, but essentially abuse. There apparently wasn't enough free play in the set up as well. Wether this was part of any of the issues I don't know.
The guy at Exedy said it should be fine to put back in as nothing was bent or damaged. I asked wether the small amount of friction material missing would be a problem and he said it would be fine. My problem now is do I take his word and re-install the clutch, but maybe risk the same thing happening, or do I change the clutch plate to a new but the same unit, or go the less hardcore organic full plate?
It hasn't been raced since original installation and I don't do burnouts, just the "enthusiastic" drive here and there, otherwise it's a daily driver with 200rwkw and 12,000k's on that Exedy clutch. I'll probably whip down to a local clutch specialist for an opinion as whats best to do once the clutch is back in my hands.
Oh, and the pics of worst clutch puk and flywheel and pressure plate.
Flywheel -
Worst clutch puk/friction pad -
Pressure plate -
https://www.sau.com.au/forums/topic/259545-clutch-experts-opinion-needed/
Flywheel -
Pressure plate -
i done the exact same thing and your clutch appears to be the same as mine,i put mine back in and have since done about 10,000km without any trouble
That's good news! Was yours the same clutch?
Any explaination as to why it did it? I have launched harder previously, just thought it was weird to do that.
Cheers.
yeah, i had a jim berry clutch do that on a skid pan.. just locked up. put simply i thru it in the bin and got an os giken. i wouldnt use it. it will do it again.
the problem is the button material thats more suited to steel flywheels/clutches not the nodular iron oem ones..
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
