  • Replies 73
Strange...I can see it in MS Explorer, but in Opera (another web browser) I can't see that page.
I suspect that there's a html error on that page that Explorer just lets through...
Cool site anyway :-)
I'll be sure to check it out again once I've got my GTS-4
Originally posted by Turbo2
Hey Rezz,
do you think you would be able to find a FEED lip for my FC over there? Have been looking for ages,  just say if you dont know what i am talking about and ill attach a pic.
No prob Turbo2...
Could you direct your enquiry to the e-mail addresses (either one) on the site? Many thanks.
I think I was K's first SAU customer :P and will write up a short review of my experience with Rezz and his company, K's Online Garage.
I ordered around $250 worth of NISMO gear through K's Online Garage and I have to say that there service was nothing short of excellent, Rezz it is a credit to you that you have wonderful customer service skills and mantain curiosity at all times. You helped me along the way by improving my order and answering all my queries and even finding a local bank account where I could deposit the cash to you. I received my order today and it was neatly packed with more then sufficent padding.
I look foward to further business with K's online garage when I purchase my R32.
Good Luck Rezz ! :)
Cheers Gary.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
