I have put two 1.5mm oil restrictors into my engine block, i still have head filling up with oil. Should have went with 1.2mm. I want to know if the drain into the bottom of the engine block, will be able to handle oil from the engine head return, from the front left, and also from a second return which will come from taking out the grub screw in the middle of the exhaust side, in conjunction with the turbo drain. Or will i need to make a fitting into the sump and leave only the turbo drain to the engine block.
Also is the grub screw that I have taken out too low in the engine head and drain too much oil at idol or will it be fine?
the grub screw thet i have taken out is the brass fitting above 3 and 4.
https://www.sau.com.au/forums/topic/259770-external-rb30det-oil-drain/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
