It could almost be a commercial for AAMI or Shannons ;)
"nice ride amigo - you got it insured?"
"nah pedro, I spent all my pesos doin it up - I'll get insurance next month"
Then the AAMI music starts as the driver of the silver car takes his eyes off the road to look at a beautiful senorita ....
https://www.sau.com.au/forums/topic/259929-youtube/#findComment-4462753
  • 1 month later...
