Hey Guys,
Pulled apart my boot stuff today in an effort to connect my 3rd brake light.
After taking out the 3rd brake light, it (obviously) wasn't connected.
What confuses me though, is i couldn't see anywhere where the 2 PIN connector should go?
Does anyone know if i can get both the spoiler AND the 3rd brake light going?
I dun see why there isn't a connector for it?
Can anyone who doesn't have a spoiler take a photo and check. The 3rd brake light just slides back and out?
I'd really appreciate it! :banana:
Big ups! :banana::D
https://www.sau.com.au/forums/topic/260077-3rd-brake-light-vs-spoiler/
My bad, probably should have explained that!
My car came with an OEM spoiler which works fine right now, im just trying to get both the spoiler AND 3rd brake light on when i tape the brake, rather than it being just the spoiler?
thanks for the reply =)
maybe they're not suppose to work together, as if you got the 3rd brake spoiler then why would you need the 3rd brake light behind the rear windscreen is for? it's probably not that visible from behind.
otherwise you can just get a cable and tap it to where the spoiler cable is... positive usually is the one with a red line or black line on the wire. if in doubt use a multimeter.
i really won't have time to pull my boot apart, as it's gonna be a very busy for me as my mother in law, grand ma in law and auntie in law are all visiting...
im prett sure legally the one on the wing should be the only one connected, probably why not the windscreen one has been disconnected. if it wasnt done during compliance, a similar law may apply in Japan
i think the regulation is there for a reason e.g. to prevent anyone attaching 50 set of brake lights like light bulbs around a moulan rouge dancer's dressing room mirror.
i'd be pissed driving behind such car with hundreds set of brake lights blinding my eyes every time it brakes.
so i think the maximum is three. that's why there's no term for 4th brake lights.
mine was not connected when i got my car, i pulled the cover at the back (rear windscreen brakes)n fount out it wasn't connected! (cable was tucked in)first i was hesitated to connect coz i was thingkin maybe too much load for my brake fuse but decided to connect wit my finger cross... now its working, no problem! i got four brake lights working! and so far no complain from cops or anybody.
Edwin, thats perfect, just what i wanted to hear =)
What was the trick to get the back cover off(rear window)? I see two small cap covers, but i can't seem to pop them off? Any hints?
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
