hey.. im looking for the r32 n1 pods.. the one just in front of the rear wheel.. does anyone know where i can get them from? or inparticular the drivers side one..
cheers
You mean the "Spats" on the rear of side skirts?
You can ask Nissan / Nismo, but they probley want a lot for it.
For Sale section would had some, but some come as the whole peice and I think genuine is separate or a 3 peice.
https://www.sau.com.au/forums/topic/260226-rear-pods-n1/#findComment-4477008
yea.. theyre 3 individaul pieces.. i need the 3rd piece.. the "spat" or whatever its called.. i lost mine last night and by the time i went back to look 4 it (about 5 mins later) it was gone..
i dont want to change to the one piece style.. want the 3 to keep it genuine..
if anyone has the drivers "spat" or both can you shoot me a pm please.. i get depressed looking at the car without it.. lol
https://www.sau.com.au/forums/topic/260226-rear-pods-n1/#findComment-4477168
  • 1 month later...
the piece in front of the rear wheel is not a seperate piece which fits onto your stock side skirts. the stock side skirts are a 2 piece item, the n1 versions are a 3 piece item (3rd piece being that item in front of the rear wheels)... ur alternative is to get a fiberglass version to stick over you stock side skirts.
https://www.sau.com.au/forums/topic/260226-rear-pods-n1/#findComment-4563003
  • 2 months later...
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
