Interstate people, I will confirm postage costs hopefully by Monday next week. So INTERSTATE - Please hold your EFT/Order until then
Ok GB on CB Radios - going ahead!
Details as per below, any issues post in the thread - DO NOT PM ME. I get too many Admin/Trader PMs a week.
Please keep all discussion in this thread. Its much easier for me to look after.
Start Date: Now
End Date:. 27/03/2009
Product: 3 Watt 38 Channel UHF CB Radio
http://www.jaycar.com.au/productView.asp?ID=DC1060
- UHF FM transmission
- No licence required
- 3,000 & 1,000mW output power
- Up to 12km transmission range
- 38 Channels and 38 sub-codes
- 10 different call melodies
- Dual watch function
- VOX function
- Stop watch function (0:00:00) - (9:59:59)
- Electronic volume
- Repeater function
- Automatic squelch function
- Battery level indicator
- Key lock function
- Key tone function
- LCD back-light function
- Supports external headset
- Supports external AC-DC charger (included)
- ACMA approval
Price: $110
(RRP is $170 for one, $135 for 10, saving of $25 for bulk purchase)
Car Charger - $10 additional cost (recommended)
Company Supplying: JayCar/DigiTech
Delivery Options:
Victoria - Pickup Only (I will organise a meet in Vic section to collect for everyone)
Interstate - Postage to be confirmed. Buyer covers the cost. I would imagine around $10-$15 depending.
Payment Details:
Accnt Name: Mr Ashley Cosgriff
BSB: 063 419
Accnt#: 1000 5658
Reference: SAU User Name
If you do not include your user name, you'll loose your money for wasting my time :P
Extra Notes!!!!!
1. Please post in this thread once you EFT so I can lookout for it. Also how many you order/if you are taking a car charger, etc etc.
2. Interstate people - If we get for EG 10 people from NSW. I will post to one delegate/trusted SAU user of my choice (if possible). Its just too much dicking around to send 10 packages as im sure you can appreciate. I hope this will be OK for people.
3. If you think you can get a cheaper brand/model - good for you. I dont care. This is through a trusted supplier (not some ebay muck around). So ye its not the cheapest going around. But its certainly the most reliable.
Confirmed Payments/Details:
1. R31Nismoid - 1 CB, 1 Charger
Any questions... well, there shouldnt be. We all know what a CB is/does
Cheers
Ash
https://www.sau.com.au/forums/topic/260656-cb-radios-hand-held-two-weeks-only/
  • Replies 57
RE: batteries - as per the add, it comes with a rechargeable battery pack or whatever...
If you want extra you can work that out with Jaycar, i doubt there would be anything major discount wise there so not worth the effort.
Plus the stock rechargeables should have a few years shelf life at least. I dont see the need for extra personally
If its only $20 in bulk (to my place, or i pickup) then thats ok.
I'll just cover that as its far easier than trying to workout the breakdown into cents.
Hey rAsh,
Put me down for a CB, charger and can you find out how much the hands free kit is coz I reckon I'll take one of those too.
I shall find out and let ya know on the mafia mate :verymad:
okey dokey Ash, i have moneys ready to go. however scratch the car charger from my order. i already have one (yes the DC-1036). will deposit $110 tonight k?
Go for it mate :wub:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
