  • Replies 57
sorry there was a delay in the order processing by the wholesaler, they finally came thru on the order. They said they were shipped to melbourne on thursday from sydney, so they'll be there on monday hopefully.
also I included an extra CB and handsfree in the order for myself, but if anyone wants to grab one and missed out on the order, hook Ash up with the payment and you can grab mine.
well they're waiting at my place in melb for ash to pick up. I'm in QLD atm so its best if you dealt with Ash directly.
Also if anyone wants to pick up one and wasn't part of the GB, there's one spare you can grab, just let Ash know so he can pick it up.
should be about $10... I'll pm you payment details for just the CB's and when I get it, I'll post em off to you, then you can fix me up later for postage or something like that.
