Hi guys,
theres alot of info flying around in other areas of the forum, so i wanted a place for people to post up pictures and specs of their oil catch can installation. Please keep this very on topic.
I will be modifying my system soon so ill post up results once complete.
Here is a useful thread to read up on. http://www.skylinesaustralia.com/forums/Ca...ans-t68174.html
Here is SydneyKid's recommended RB25 setups. http://www.skylinesaustralia.com/forums/Ca...html&st=20#
Thanks.
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/
  • Replies 52
Posted Images
If anyone has any pictures of a RB26 with a oil catch can setup, that'd be awesome.
All I ever see is RB20's and RB25's with oil catch can setups with extreme diagrams and walk throughs.
Theres 3 that ive seen... ones the autech can that sits on top of the rb26 at the rear..
The other is one that sits in front of the battery - Blue32 had one of these
And theres another one which is an oil/air separator (nismo, non vented) that hides underneath the ABS unit...
Maybe andrew can take some pics of his current setup as from the sounds of it, its pretty bulletproof
-D
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4475132
heres a can for the 50% plumb back option:
http://cgi.ebay.com.au/UNIVERSAL-OIL-CATCH...A1%7C240%3A1318
3 in/outlets, removable top so you can pack it full of steel wool (in a stocking!)
That looks like a similar design to the one that ISC sells ;
http://www.isc-warehouse.com/index.php?mai...products_id=245
-D
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4475719
Hey, i got the same one as that...havent hooked it up yet but where do you connect the hose to at the bottom of the can- like where does it go to
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4477065
Drifters catch can of choice.
Serious note.. I run 2 as its neater, I'm not a fan of hoses draped over the motor.
One either side of the motor feeding off that sides cam cover.
One sitting in the drivers side engine mount and the other behind the A/C compressor.
Since oiling mods the cans are always empty.
Edited by TheRogue
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4477090
Have you got a pic.....still deciding how i want my setup to look
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4477097
An engine bay pic would not be useful as it looks like a standard engine bay. You can't see hoses or catch cans.
I'm soon to rip the cams and lifters out again so I'll grab some pics of the bits underneath the manifolds.
If you can visualise...
The passenger cam breather that runs to the inlet pipe has be redirected in to the catch can that resides behind the a/c compressor / under the exh. manifold.
The hose that runs from the drivers side cam cover to the PCV/plenum has been blocked and a T piece positioned in the middle; a hose connects to the bottom T piece connection and runs under the manifold to the engine mount where the catch can is located.
Really depends on how tidy you want the engine bay to look.
Edited by TheRogue
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4477486
RB26dett catch can set up.
Heres a thread for the autech type over the head unit
http://www.skylinesaustralia.com/forums/JJ...nt-t166910.html
It's a sealed catch can and has no breather and so is legal thru regency (they might say otherwise, but the legislation allows oil/air separators that don't have an atmospheric vent
there is another type from nismo ;
http://www.rhdjapan.com/jdm-low/NISMO-Oil-...-Kit-GT-R-55665
Which I imagine does the exact same thing as the ISC can since I can't see an atmo vent anywhere on the it (unless I'm missing something - $800+ AUD vs $50 aud? Crikey.)
I think eventually I'll get the ISC one and the Autech can as well as drilling an oil return from the head and putting in 1.5mm stoppers in the oil channels, and a sump baffle from somewhere. That should be enough for any street car.
-D
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4477492
lol Joel, you redeemed yourself with that last line :)
seriously Damo, unless you've done what Joel and others have done in relation to baffles and restrictors, do not try this method.....2 laps around Malalla and they'll be full.
I still believe that the 2 can setup that I described earlier is still the best for no other mods to restrict the oil
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4477854
ROFL!
Definitely agree. Mine has a fair bit of oil pressure over 3500-4000rpm (~90-95psi).
Without the oiling mods the cam covers were filling on the dyno to the point where I could only just see the lobes poking through the top of the oil level, oil was blowing out and filling the catch cans in no time.
After the oiling mods there's only a slight puddle of oil after a hard extended run and no oil in the catch cans. :blink:
Edited by TheRogue
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4478175
yeah funny how quick the oil gets up there and how slow it drains back, hence why a popular mod is to relieve the oil returns in the head slightly....suppose everything helps.
Here are a couple of options that will also help oil drain back while the head's off....welsh plug replacement at the rear of the head and fed back into the sump (just to help speed things along).
https://www.sau.com.au/forums/topic/260910-oil-catch-cans/#findComment-4478488
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
