Hey just bought and installed a new JJR dump and front pipe on my 33.
Just wondering if anyone else has encountered problems fitting them? I have access to a workshop with hoists etc and went to fit it today only to find that one of the bolts on LH side of the turbo wouldnt go in as it was hitting on the pipe. I expected a bit better quality from a product which ive heard so many good things about?
Also had to remove the main heat shield around the turbo (just to drive home) as it too wouldnt line up and was hitting on the pipe.
Im thinking of getting the oxy out tom. and adjusting the pipe slightly to get the last bolt to fit.
Was wondering if anyone else has had probs with this or has any advice??
Edited by sam0633
https://www.sau.com.au/forums/topic/261009-r33-s2-jjr-dumpfront-pipe/
ive got the bell mouth version. went on my 33 s2 with some effort.
took couple of hours, couple of jacks, couple of axle stand and a couple of guys.
yes the nut/blot on the LHS is pretty close to the mouth. we just tightened this one up first with a ring spanner. then tightened the others
finished off the tight one then finished off the others. took about 40 mins to do that, slowly.
i also took the heat shield right off and didnt put it back on.
yeah i know wat u mean hey, problem is i cant even get the bolt started in the thread, let alone tightened. and yeah i got the bell mouth version too. got very annoying today and after alot of cursing and 3 hours under the car decided to leave it for another day
ya, hrm. its was tricky. we attached the cat end first then one guy above the car pushing hard on the pipe then one under the car with
a ring spanner tightening it up 1/4 turn at a time. until it was tight enough that it was easier to do up.
we were considering hitting it with a few times with a flat edge piece of metal and a hammer, something like the end of a large'ish nail.
but we got it in so didnt need to.
this one thing too the longest to do.
luke a mech will be able to do it in 2 hours easy.
also image attached for more info.
because the pipe bends back in on its self in that spot there is very little room for the bolt to turn, let alone get a spanner or drive on there.
once we got it started it was easy.
got it all sorted after messing around at my work for a few hours. ended up starting that bolt first while holding the pipe to one side and then yeah doing it up with a spanner about 1/10th of a turn at a time. took ages but got it done. also managed to alter the turbo heat shiled and fitted that back on too. cheers for the advice, heaps happy with the performance too car feels alot quicker :P
i got the same prob, but from a custom made 3inch bellmouth dump/front pipe (may even be the JJR one got it 2nd hand) and the 2 middle bolts on the flange dont wanna go in, the heads of the bolts hit on the pipe, so i cant even get it started let alone fit a spanner on it! there is no leaks the 4 bolts on atm are holding it on fine no probs i just wanna have all 6 in to pass pits if i need to, so ive got some alan-key head ones with a small diameter head i may be able to get in (just cbf and no time lol), so for that bracket on the dump pipe i didnt put mine bak on as it was a bitch to work around it to get the bolts in, but the heatshield is still held on by 1 bolt, yes 1 bolt on the bottom left, the top one snapped, and ive just dummied 2 bolts where its supposed to go on the dump pipe bracket so it looks like its all bolted up if a coppa wants to stick his fat head under my bonnet, its held in place fine just not tightly and i doubt a cop is gonna wanna shake my heatshield with his hands just to check if its on secure.
Fitted my JJR bell mouth dump yesterday to my R33 Ser11 was one of the easiest bolt on exhaust upgrades ever,took about 90min from start to finish including removal of old dump/front pipe.I used 2 allen key bolts on the 2 middle holes where it is closest to the pipe no interference problems with this method also wrapped dump pipe from bell to just below firewall with heat wrap,original turbo gaurd and mount for this went back on without having to alter them at all,trick is start all bolts at bell end first then connect collector end and then return to bell end and tighten all bolts in a cross sequence then tighten collector end last.I have fitted many extractors to v8s and you should try fitting a set to a big block chev into a GTR torana talk about dramas like trying toi stuff a size 12 foot into a size 6 shoe.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
