Congrats Rob and Co! You must be rapt :blink:
He ran 4 7s at a meet today at Meremere NZ, all at around 176mph and the fastest of which a 7.89 @ 176mph (basically in limiter in top gear) after tuning the car for a bit more boost this week. Still running the Nissan crankshaft!
What is the fastest RB30 powered drag car anyone knows of?
https://www.sau.com.au/forums/topic/261181-rips-240z-into-the-7s/
And what is the minimum for the next class you're looking at?
Is there any point selling the zed? Since you've come so far wth it, if all it needs is new ratios and a trip to weight watchers - wouldnt you want to see just how far the little datto can be pushed? :P
600kg minimum for the next class we'll have the motor in (but it'll probably be around 750kg all up) and then 765kg minimum for the class we intend to run after that or if we go back to Pro Import 1060kg.
Is there any point selling the zed? Since you've come so far wth it, if all it needs is new ratios and a trip to weight watchers - wouldnt you want to see just how far the little datto can be pushed? :thumbsup:
The 240z is a street car (missing headlights, wipers and a muffler, it has a 6 point street cage, glass, full dash etc, its short, it has a high COG and it has done more than I ever thought it could do, its time to get the motor into something purpose built.
Rob
What the hell is in the r32 at the 4min 18sec mark?
Another RIPS RB30'd car?
Nah, it belongs to Joe Kyle (aka Yoda) - a lad who runs his own shop in West Auckland and been around with that car for ages. If I remember rightly it runs a fully built stock displacement RB26DET with a T51R SPL on pump gas and full normal street tyres, he's not a forum goer to my knowledge or anything but its a very very tough streeter.
Edited by Lithium
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
