This is just an expression of interest at the moment. I have an opportunity to get myself into a very clean M3 that I have loved and eyed of for years.
My Veilside GTR has just been in the workshop for 5 weeks and have spent $11k at Creatd Motorsports on the following items-
Fully reconditioned Head with New Steel Cometic Head gasket.
Head Studs.
Injectors.
New Garret 2860-7 Turbos.
Apexi Power FC.
Front Dump Pipes.
Trust Greddy Cam Gears.
HD Creatd Spec Clutch.
DBA Slotted Brake Rotors Front & Rear.
Full Diff & Gearbox service.
Gizzmo Boost Controller.
Brand New ISC Radiator being fitted ATM.
Car has 122,000kms, Brembo Brakes, Momo Steering Wheel,Tinted Windows,Bosch Fuel Pump and is in AMAZING CONDITION. Car has 2 tunes with 275awkw on 18psi and 325awkw on 21psi.
This Veilside Evolution R32 GTR is the only 1 in Australia and is a collectors item, hence this is only an EOI at the moment as I am only willing to sell at the right price and while this M3 is still available.
PLEASE SERIOUS BUYERS ONLY!!!!
PRICE-$29,990
CONTACT JAMIE ON 0401-004-999 OR PM.
  • 4 weeks later...
Had a Guy from Sydney looking at past few weeks, but sale fell through!! Its worth the plane fare and truck back I can assure you!!
I have put it up For Sale on Carsales for $32K as M3 Sold but actually need to sell for business reasons now!!
So Car is now For Sale on here only at $29,999!
Just to let you know, I have now raised the price to $34,950 on carsales as I am now not so desperate to sell and will only sell at a price or trade with a car that I am happy with. Still taking offers and trades but this is the new bench mark.
Thanks
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
