Don't make me have to teach you how to shift Mr whippy :P
going to try and put on teh super dragger tonight!
buzz me when your free or are shall i call the ambo for you? haha
Edited by Redsuns88
Yes i dont think you have quite mastered the art of "Ballz on chin" like funkymonkey did, but you never know.. sat night you may master it!!
lol haha zing
Edited by Redsuns88
ha i have no experience with balls on chinn - itll stay that way,
however
ive noticed since funkymonkey has been in melb your progress has been poor.. :P
Always can,
Cannot promise I will be sane most of the time..
supposedly i have a dry humor problem :S
Nismo boy where is jooor office!?..
i might make astrotristian rip a sik skid in his undies for u!
haha lol
Moggill road... Chapel Hill end :P
yeah that berry blast was good, apart from the masses of ice...
so much for fitting the dragger, f**kin 1 pce cat. :blink:
tar.
ps: qld section is poor.
I'm from Kenmore/Paddington although if your having a meet soon I'll only be able to rock up in my parts runner as my broad minded person it getting worked on at the mo :S
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
