HDI kit rox! my undies!! he personally delivered it.. Lol customer service ftw!..
Shame your sick, had fun times while out with astro and funkymonkey tonight..
astro and funky was talking about the whole gecko stances and smashing boxes!! :S :wacko:
Meet this thursday!! 23/04/09!! Baskin and robins then maybe off the car wash for abit of detailing!
--Since the economic downturn there's a certain rumor that funkymonkey is doing topless washing for 5 dorra! that's right people you heard it here first 5 dorra he/she will never tuck it in and will use a corny asian accent!
Sup this thursday! we def doing something if you can get transport there thats cool if not pm me and ill organise to pick u up
Busy thursday night installing another Vi-PEC in a drag car. Bugger
wont be home from work till about 6 :S and will take me 45 mins to get to moggill rd. im on the southside but definetly keen for meeting up with everyone.
hey hope to be back at work thursday, count me in. redsuns i require your personal taxi service, but if the taxi's full i bring the drift beast. hope im feeling better, ive already missed out on so much this week. :P I'm gona hit the boys at PCE for a cooler kit to, its a good price. gotta sort out halfcut with funky or are balls on chin in order?
well as thursday is my birthday i rkn u f**kers are buying my icecream :P
redsun ill swing you a buzz either tonight or tmr morning about times, but yeh after 7ish is betteer
its cool to see al the interest - im keen to meet some of you guyss
So i just woke up... Astro are you saying since if your birthday, birthday punches are in order? :) :)
after a night of a certain monkey licking himself in my car.. i hope i have not been contaminated with cold/flu and or gayish tendencies hahaha
im liking the idea for this meet its making my pants tight! :D
Meetup sounds fine i reckon with the people who make it in early.. just come and chill and wait for the others.. then after that we can head to the car wash for abit of a wash and shiz... otherwise if peeps want to roll after the ice cream its all good :D
I'll be picking the missus up in the city at 7. So I dont think I can stay that long if the meet is at 6... =x I work in Milton and knock off around 4-430. If anyone wanna meet up earlier I'll be keen.
im in brisbane for a few weeks working so if anythings doing let me know
What the ?
Take my head back down with you :)
Funkeh, fancy a game of pool? haha
Name the stakes dark one.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
