well im down for baskins and robbins - prepared to give the girls one more chance, but funky wants pizza - so that'll be in kenmore or bardon..
How's about real food and ice cream after ya tight ass.
im sorry all i heard was;
"come over boys - hang out at josh's house, ill cook"
cheers buddy - im keen
I live in Bulimba..
There is some pretty epic cheese cake in the fridge at my work though. *looks out window* Redsuns 180sex has lost it's space saver :D
Whats your daily car?
and yes my car has lost its space savers.. its about to be changed into 2 space savers on the rear..
it will be a epic skid at the track or a epic skid in my undies when the rubber rips off
im sure we can go for pizza then ice cream.. but i nejoy washing my car and stuffzors.. lol but im just down with the crowd since im such a peoples person....
now..wheres my bobcat photos :S
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
