as for smithy, f**k man those results are rather depressing.
150+ is what u want, 140's at the lowest. And within like + / - 5
hope you got cash, she'll have to be cracked open... :P
I'd be wanting 160+ actually. Nissan specs say with +/- 14, but yeah 5 or 10 at most would be better.
Was planning to crack it open anyway, as something is definitely farked.
Don't you know R31 drivers never have cash? :( jks
yeeh man, albert rear ended me :(
gaaaaaaaaaay
Totally normal. Only normally its Taz rear ending you...
boot lit, reo, rear bar, reverse lights, rear lights :)
depressing
Your always depressed...emo :(
haha suppose so,
its just gay and such an inconvienance - gota get two quotes today,
any recommendationss ppl?
I would use
"You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake! You almost had me?"
"You know what? This will decimate all... after we put about fifteen grand or more under the hood. If we have to, overnight some parts from Japan."
Two great quotes right there :P
Damn sorry to hear that man.
Might be a bit out of your way but I'll recommend:
G A Wolfe & Co
173 Toombul Rd
Northgate
(07) 3266 3312
He did a FANTASTIC job on my car when i was rear ended by a falcon. He's a just cars authorised repairer too if you are with them.
Well jeez, you should come along to the next meet then!
I think the plan is meeting at the Baskin Robins next Thursday night but keep an eye on this thread for more info. The plan has a week to evolve :P
Anyone wanna meet up for dinner or something? I'll be knocking off from work after 4 and heading straight to Godzilla for a chat with Mark. So... dinner after that anyone?
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
