as for smithy, f**k man those results are rather depressing.
150+ is what u want, 140's at the lowest. And within like + / - 5
hope you got cash, she'll have to be cracked open... :P
I'd be wanting 160+ actually. Nissan specs say with +/- 14, but yeah 5 or 10 at most would be better.
Was planning to crack it open anyway, as something is definitely farked.
Don't you know R31 drivers never have cash? :( jks
yeeh man, albert rear ended me :(
gaaaaaaaaaay
Totally normal. Only normally its Taz rear ending you...
boot lit, reo, rear bar, reverse lights, rear lights :)
depressing
Your always depressed...emo :(
haha suppose so,
its just gay and such an inconvienance - gota get two quotes today,
any recommendationss ppl?
I would use
"You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake! You almost had me?"
"You know what? This will decimate all... after we put about fifteen grand or more under the hood. If we have to, overnight some parts from Japan."
Two great quotes right there :P
Damn sorry to hear that man.
Might be a bit out of your way but I'll recommend:
G A Wolfe & Co
173 Toombul Rd
Northgate
(07) 3266 3312
He did a FANTASTIC job on my car when i was rear ended by a falcon. He's a just cars authorised repairer too if you are with them.
Well jeez, you should come along to the next meet then!
I think the plan is meeting at the Baskin Robins next Thursday night but keep an eye on this thread for more info. The plan has a week to evolve :P
Anyone wanna meet up for dinner or something? I'll be knocking off from work after 4 and heading straight to Godzilla for a chat with Mark. So... dinner after that anyone?
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
